Question about Dryers
Brada dryer dryer will not heat up
  • Dryers Master
  • 7,482 Answers
Hi Dennis
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the heating element/thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me
Bud
Posted on Apr 25, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My 2 year old Brada
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Aug 05, 2011
Part for brada dishwasher model EB2402WW or manual
Fixya does not sell replacement dishwasher parts. Check with a local appliance parts supplier.
Try Googling (Brada)(EB2402WW)(manual) without parens.
Oct 10, 2016 | Dishwashers
Where can I order Parts For A Brada Dryer
Hi Armand,here's a link to some control knobs,if these are not them,let me know and I will search more.You can give me your dryer's model number. Samsung Dryer Knob Dial Button Parts
Feb 08, 2016 | Dryers
I have a brada dryer that runs for two minutes then shuts off. It shows a code . I tried my braker switch didn't help. Cleaned it all out and still the same.
Brada Appliances Product Support ' ManualsOnline.com
www.manualsonline.com/support/brada/
Manuals and free owners instruction pdf guides. Find the user manual and the help you need for the products you own at ManualsOnline.
Sep 30, 2015 | Dryers
Where can I find replacement wheels for a brada portable dishwasher model EP9242AWW?
1. Google: "Brada Dishwasher Parts" and select one of several options
2. Amazon is also advertising appliance repair parts.
Pete
Sep 28, 2015 | Dishwashers
My Brada dryer won't turn on again for about 30min after only drying one load.
SOUNDS LIKE COULD BE A BAD MOTOR WINDINGS PROBLEM? If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Feb 15, 2015 | Dryers
Brada Dishwasher flops forward
I am not familiar with your Brada, but in the US, nearly all dishwashers that are "built-in" have two tabs on the top edge that are supposed to have screws put thorough them to hold the dishwasher to the counter top. Many do not, (poor installation) and many fall forward as your is doing.
Be blessed.
May 21, 2013 | Dishwashers
Belt Diagram for Brada Dryer
Call the manufactor to send you one for your machine.
Jan 02, 2013 | Samsung ASSY DOOR;BRADA-DRYER -...
Brada EP2402WW/BB dishwasher
Where can I buy parts for my Brada portable dishwasher model number EP2402WW/BB.
Dec 01, 2012 | Dishwashers
My 2 year old Brada dryer won't heat up. The breaker is fine.
heatman101
Aug 01, 2011 | Dryers
HOW DO REPLACE THE HEATING ELEMENT OF THE BRADA BED70W DRYER?
There is a video on YOUTUBE on the complete disassembly of the Brada. Follow that to access the heating element for removeal. You can also remove the discharge piping on the back to access the heating element electrodes. remove the wire clips and put an ohm meter accross. you should have some kind of resistance on the meter. There is also a video on how to use an ohm meter.
Mar 08, 2011 | Dryers
Dryers Logo
245 people viewed this question
Top Dryers Experts
