Question about Konica Minolta Bizhub 600 750 Image Control Board 57aa-9016g
Error 2101 - Konica Minolta Bizhub 600 750 Image Control Board 57aa-9016g
  • Konica Minolta Master
  • 6,161 Answers
Sir/Mam,
On the drum cartridge above the drum is a small assy. with a gold plated wire very, very thin. Anyway there is a motor that send a cleaning device across the wire to clean it well the code you have indicates that there some wrong motor burn out, jammed some how stuck or the home sensor is bad tells the copier I went out and came back cleaning done. Remove the drum cart to check on it. Recommend a tech do that don't want to do anything to the drum.
Posted on Jan 01, 2015
Error 2101 hdd
Hard Drive failed and may be damaged.
Dec 29, 2013 | Fujitsu LifeBook Computers & Internet
Error c - 2101
PC charge cleaning.Remove the charge corona and clean the charge corona cleaning motor parts and verify the contacts.,and the wire cleaning pad.
Feb 25, 2013 | Konica Minolta Office Equipment & Supplies
Im getting dns and dlns error codes when trying to access movies on my ps3 the codes are 2101 501 media server errors
well basically all youve got to do is to ebgehjbfbxjanvuvjsdbvzhjehvhghvhavxhjavhxvhjxaf and then it should work
Nov 03, 2010 | Computers & Internet
Scanning error 2101 scanning to smb file
you have to have a user name and password set up on the computer you are scanning to then you set that up in the address you set up on the copier.
Mar 25, 2010 | Kyocera Copystar CS-1820 Black and White...
Getting error code 2101 when scanning a document into our kypcera mfp cs 1820. What is the error and how does one fix it?
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
Mar 02, 2010 | Kyocera Copystar CS-1820 Black and White...
C 2101 on bizhub c451
this error code means there is charge cleaner malfunction. during the backword movement if the cleaner the home sensor was not actuated after a predetermined amount of time. to reset the error code leave the machine on and open then close the front door if the charge cleaner motor has been disabled in service mode this error code will happen at start up
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
ERROR CODE 2101 WHEN TRYING TO SCAN
Oct 30, 2008 | Kyocera Copystar CS-1820 Black and White...
KM 3060 Scan Error 2101
Hi Guys,
I was getting the 2101 error as well. I resolved this by placing the IP address of the computer into the "host name" field. Only thing to remember is that your IP address will change from time to time. You will need to assign a static IP to that particular machine or give it a reserved IP address through your switch. Good luck!
Oct 14, 2008 | Kyocera Mita FS 3800 Laser Printer
Konica Minolta Bizhub 600 750 Image Control Board 57aa-9016g Logo
131 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
