Question about Vizio GV42L 42 in. LCD Television
Thin white static line at top of screen for some channels vizio 42 lcd hdtv
  • 4 more comments
  • Anonymous Mar 16, 2009
    white and black lines at top of pictureon some channels
  • Anonymous Apr 06, 2009
    Mine has the same white static on the top with non hd channels
  • dmaza Apr 20, 2009
    Static thin line on top of screen, same as what was already posted.
  • Anonymous Apr 22, 2009
    same exact problem
  • Anonymous Apr 26, 2009
    I have the thin static type line at the top and (rarely) bottom of my screen. It does not always happen, but is there at least 50% of the time.
  • Macirfro May 12, 2009
    New Vizio 37" LCD with same problem. White static line is visible on some of the non-HD channels.
I had the same problem and it was fixed by enlarging the picture size or v-position. works great now.
Posted on May 06, 2009
    New Friend:
My vizio tv develop a split screen, split is down middle top to bottom
Posted on Jul 21, 2013
  • 40 Answers
I have the 37" lcd and 50" plasma both vizio. don't know what it is but has to be in the signal from cable co.
Posted on Mar 13, 2009
We purchased a Vizio 42"
This is more of a provider problem. Report the signal problems to the service you subscribe to for tv.
Mar 23, 2011 | Vizio E420VA 42 in. LCD HDTV
White flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
May 15, 2010 | Vizio GV42L 42 in. LCD Television
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
Horizontal lines on 42" vizio LCD
i have the same problem. any solution
Dec 21, 2009 | Vizio VW42LF 42 in. LCD HDTV
Goodman 42" HDMI TV 5 years old has thin lines on the screen
Appears most probably to be a fault in the inbuilt power supply capacitors. Getting them changed once solved my problem. If you opt to change yourself then don't blame anyone if it renders your TV unusable!
Jul 29, 2009 | Vizio VA26L 26 in. LCD HDTV
Small line of static at the top of the screen
i solved this by enlarging the picture size through setup, or the V-position.
Mar 26, 2009 | Vizio GV42L 42 in. LCD Television
Plasma TV moving black and white lines
This is a result of poor conversion of a SD signal on a HD channel.  Go into your settings and adjust the h/v settings to move the line off the screen.  You can do this with a combination of v-position or vsize.
Jan 26, 2009 | Vizio GV42L 42 in. LCD Television
A horizontal line on the top of the tv when viewing some channels
that is normal, many tv's have this, just change the screen size, does this happen on hd channels too? or only regular channels?
Jan 21, 2009 | Vizio L32 32 in. LCD HDTV
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Vizio GV42L 42 in. LCD Television Logo
2,852 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
