Question about LG VX8300 Cellular Phone
I have a Vx8300 i dropped it and the screen tirned white.
I barely dropped my Vx8300 on the floor the screen turned white, i tried dialing *228 it didnt work, any suggestions?
  • 2 more comments
  • meccaneer Apr 13, 2009
    I dropped my phone (for about the 10th time) and the main screen turned white.  The front screen does not light at all.
    The phone will still turn on and off and will even ring when a call or text comes through, but I can't see anything.  It doesn't make sounds when I push buttons.
    I took the back off to see if some wires had come undone - didn't see anything immediately, but I will keep looking.
  • meccaneer May 11, 2010
    I opened up the back of the phone (#0 philips) and reattached the orange cable.  The screen is still white.
  • nms5380
    nms5380 Oct 30, 2012
    same exact thing here man. find a solution?
  • nms5380
    same thing happened to me. front nothing. and main screen is all blank white. any luck yet?
  • 173 Answers
On the 8300, the LCD is connected woth a flex cable to the main board. It might have loosened at the connection oint or you might have damaged your LCD. Either way the phoe needs to be opened up and checked physically.
Posted on Mar 13, 2009
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
Feb 21, 2014 | Eureka Vacuums
I have a lg model no vx8300 i cant unlock
The default lock code is the last 4 of the phone number. If that does not work dial *228 send and option #1, this will reprog the phone and reset the lock code to last 4 of phone #
Apr 27, 2010 | LG VX8300 Cellular Phone
Brush will not spin
Hello :
Try this: switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
PLEASE RATE !
Apr 19, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a used LG vx8300 phone and have locked myself out, how do I unlock it?
the lock code is by default the last 4 of the phone number...if that doesn't work dial *228 send and choose option #1 to reprogram when its complete it will power cycle and then the lock code will be defaulted back to last 4 of phone number
Dec 25, 2009 | LG VX8300 Cellular Phone
I have a 13 year old daughter, andhave taken her phone away from her. She locked the phone, and I need to see what is on it. How can I unlock the phone? It is a LG VX8300. Thanks
Sometimes, the last four digits of the phone number will not work as the unlock code, especially if your daughter has changed the code. Even if the phone is locked, dial *228, then press 1 when prompted by the automated system. When it tells you: "Your phone has been programmed successfully", press "Done" or "OK". Once the phone has powered off, then back on, (it will do this automatically) the lock code for the phone will be changed to the last four digits of the phone number. For example, if the phone number is (315) 123-0101, your lock code, after following the above instructions, will now be "0101". Also, you do NOT need to know the lock code that your daughter had for this to work. After the phone has powered back on automatically, you will be able to use the phone normally. *228 does not delete text messages, contacts, etc, but it WILL give you access to a phone which has been locked, without requiring you to know the code that she has set.
Jun 24, 2009 | LG VX8300 Cellular Phone
Signal
Dial *228 option 1 and try again. If that doesn't work then you have to call your wireless carrier and have a data feature refresh done to your line.
May 02, 2008 | LG VX8300 Cellular Phone
Revert back to 1x only
EV does not drop calls as it is not used for calls. EV is ONLY a broadband network .. In other words, it does not transmit voice ... Only data ;)
If your dropping calls then try turning the phone off ..then back on then dial *228 then option 1 and see how it does then.
If your calling other cell phones and it's dropping calls then it's 50/50 as to who's at fault there.
Apr 11, 2008 | LG VX8300 Cellular Phone
Unlock LGVX8300 passcode
Try dialing *228, then pressing 1. This reprograms the phone to factory defaults, making your security (lock) code the same as the last four digits of your phone number. For example, if your phone number is (315) 123-0101, then after following the above instructions, your passcode is now "0101". *228 is accessible EVEN when the phone has been locked. This method does NOT delete contacts or change your phone number. All of that information remains the same as before you dialed *228. Also, you do NOT need to remember your old passcode for this to work.
Nov 21, 2007 | LG VX8300 Cellular Phone
Lg vx8300
the screen will need replacing but if the phonr has been dropped it migh just have slipped of the connectors this is a job for a phone shop as you can damage the phone further buy taking it apart cus the static in your body will blow the circuits it should be cheap to repair and even a new screen can be cheaper the replacing the phone hope this is some help to you...........................
Oct 29, 2007 | LG VX8300 Cellular Phone
My phone displays a white main screen
My Solution: Heat it up by just sitting on it or holding it in your hands// Take the battery out and back in/ Try keeping the battery out of it for a full day
My Story :) My mom dropped the phone in the dishes because she was drunk haha, I quickly took out the battery, but when the next day came by I looked at the phone and saw the same problem everyone here has. I kept replacing the battery on the hope it would just magically fix itself. Now 2 days from when it dropped in water, I kept flipping it, replaced the battery again (just taking it out and back in) after I sat on it a while, possibly the heat somehow helped it to work again.. I'm amazed it works haha, it was in the water fully submerged for half a min when I had to snatch it out of the dishes But, it is most likely that I took the battery out, the battery is the thing that ruins electronics, just remember to take it out if you drop it in water. Good luck. If worst comes to worst and your going to buy a new phone, maybe try using a blow dryer on it for a little bit **or just do this in the first place**
Jun 28, 2007 | LG VX8300 Cellular Phone
LG VX8300 Cellular Phone Logo
291 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
