Question about Toshiba Satellite M115-S3144 Notebook
Hard drive replacement
How do I determine what hard drives I can buy to upgrade my Laptop? And will the recovery CD that came with the computer restore windows on the new drive?
    Scholar:
  • 26 Answers
Hi cloudsurfer,
Your best bet is to remove the old hard drive and check the brand name and model number and then go to the manufacturer's website online and look for similar models with the new features that you want.  Make sure there are the same physical dimensions.
A recovery CD will not install windows on a fresh harddrive, to do that you will require a windows install CD.
Hope this helps, and please take the time to rate!
Posted on Mar 13, 2009
F11...system recovery in hp laptop
System recovery is for serious disk/operating system corruption problems. There is a system recovery partition on HP laptops that contains routines to restore your laptop to the configuration it came from the factory with. Backup all your personal files to a CD or USB stick or portable hard drive before using system recovery as it will erase anything you have added to your primary hard drive since it left the factory. That can especially be a problem if you have upgraded to a newer version of Windows than what your laptop came with, as HP is somewhat 'known' for not upgrading the recovery partition if you don't have recovery CD's for the new operating system bought from HP. If your recovery partition has been erased or corrupted, you will have to either use HP recovery CD's (which may be available from HP if your laptop is new enough)
or do a format and complete installation from the proper Windows installation CD. Either way, your personal files are toast if you don't back them up first. In some cases of operating system failure, you can get an external USB drive box, put your old HDD in it and use another computer to try and read files from the disk to try and save your personal files.
Jul 23, 2014 | Computers & Internet
I have a Gateway laptop that I have had some issues with Windows. I attempted to use the Gateway recovery function on my laptop. I downloaded the drivers app and the 3 recovery disk. When I did the...
It sounds like one of two things, either your hard drive is bad, or the formatting on your hard drive is so bad Windows cannot deal with it. To troubleshoot it try booting the computer up with a live run CD or a bootable USB drive and see if the hard drive is accessible . If you booted up with a live run CD or bootable USB drive that has an operating system on it you can reformat the drive (provided it opens) and that will do it. If it does not open, or is not accessible you will have to replace the hard drive
Dec 13, 2013 | Computers & Internet
Operating system not found
No, you won't get the OS to automatically install on the new drive. The OS is not stored in the BIOS chip (or a similar permanent location inside the computer). You will need an OS install disc (not an upgrade disc). Windows Vista Home Premium or Basic was the original OS on most of the Acer Aspire 4530 series. Acer appears to have drivers for the system for XP through Windows 7 to get the hardware to work. You will need to have these most of these ready before you install your OS. Put them on a flash drive or optical disc using another computer.
This computer may work with Unix as well. However, driver issues may be a factor. You can try most versions of Unix from a CD (LiveCD) to test it out.
When you get a new hard drive, install it into the laptop. Then put the OS disk in the optical drive bay. Boot to the optical drive. Follow the directions for formatting the hard drive and installing the OS. (Of course you will need a drive that doesn't have a higher capacity than the BIOS supports.) The motherboard needs to recognize the drive.
If you find a member of a Windows User Group, they may have Windows install discs available. The license number on the label of your computer will probably work as your license key. (The key for a computer like this is locked to the CPU and motherboard; unless someone upgraded the OS to Windows 7 or downgraded to XP, this should be the key you need.) Use the information on the label to obtain the correct version of Vista (the Basic install disc may not work for installing Home Premium). You also need to match the 32-bit or 64-bit install disc (and the service pack you need).
I hope this helps.
(An Acer recovery disc wouldn't help you. Most of those are completely locked to the original hardware (including hard drive) and look for the recovery partition that was on that hard drive.)
Dec 05, 2012 | Computers & Internet
Acer 5334 stuck on e recovery management screen
By stuck do you mean that each time you boot the computer it goes to this screen? If this is the case then unfortunately this means something has happened to the installation of your operating system on your hard drive and in order to get Windows to load, you will need to perform this recovery. This could be caused by any sort of damage to the partition that the OS installation is on which could be caused by hard drive failure, corrupted data or physical disk damage.
I hope this helps.
Jun 27, 2011 | Computers & Internet
Gooday Toshiba Experts, My 30MB hard drive HDD2181, has apparently a lot of bad sectors. I am able to format it with a recovery CD. Recovery process is aborted repeatedly. The laptop is Satellite...
With so many bad sectors preventing a format, I would recommend the purchase of a new hard drive. You will most likely need to buy an IDE 2.5" hard drive for your laptop. However, you should double check the manual to see if it uses IDE or SATA. You can get whatever size hard drive you want for it.
I wouldn't recommend any manufacturer over the others, they're all quite similar, almost some people have their own personal preferences. Just look for the correct drive type, space you want, at the price you want. Don't focus too much on the manufacture.
The new drive can be formatted with a recovery CD, however it would be easier to format with the Windows CD when you reinstall the operating system.
May 03, 2011 | Toshiba (HDD2181) (hdd2181-50pk) 30 GB...
How to format my acer 5620 without cd ?
Unless you have a cd for that version of windows in OEM style for xp and any for vista you will be out of luck. If you have another computer with the same OS and have its operating system installation cd, you can use this if it is the same version.
Windows XP needs to be exactly the same thing. Windows XP pro, home and media center are all different. So are Retail, Upgrade and OEM cds. For vista or 7 any disc will work that matches the version type, it will determine the version by the COA.
If you do not have access to any cd/dvds then you can contact Acer for a replacement. www.acer.com
Mar 02, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
My hard drive crashed and I had to replace it. I
Insert the recovery CD into your computer.
Restart your computer, and choose "boot from CD".
Yes, the CD should include everything to reset your computer back to the "factory" settings.
Nov 14, 2009 | Acer Aspire 3680 Laptop
Sony laptop hard drive options
In your laptop you cant upgrade your hard drive. Go for the web search for upgrade options , try it in sony web site please inform to fixya.com for any other porb.
May 14, 2008 | Computers & Internet
Lost CD-Recovery
If you are speaking for your laptop, double click my computer and see if you have a D drive, most newer computers have a partition on the hard drive that has the recovery feature installed on the D drive. You would need to boot in the SAFE mode if possible and go to the D drive and run setup.exe. If this is not possible, you will have to purchase a new operating system CD and probably have to download drivers from Toshiba for your laptop. Good Luck - BPCS
Dec 13, 2007 | Toshiba Satellite M45-S2692 Notebook
Hardware upgrade
yes you can , go buy a laptop hard drive of your choice, and you will need to take the ram out and take it to where your gonna buy the hard drive , so they can see what type of ram you need, removing the hard drive and ram is easy , im sure if you take the laptop in to a computer store they will do it for you free, and put the new ram and hard drive in , it is a very quick proccess, if you want to upgrade the cd/ dvd drive , you will need to go to a laptop computer store , just type laptop in yellopages and im sure that will find you something, or what ever phone directory book you use where u are from
Nov 21, 2007 | IBM ThinkPad T22 2647 Notebook
Toshiba Satellite M115-S3144 Notebook Logo
82 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
