Question about Hammering
Home electrical the other day my daughter left a hair straightening iron plugged in causing the breaker for the bathroom to trip. i went to the breaker box, located the breaker attempted to reset it and it did not. i pused the breaker to the right to the off position and then to the left for the on position, the breaker goes to the middle. i attempted this several times and each attempt produced the same result. do i need to replace the breaker?
  • 3,289 Answers
Hi Sammy,
It sounds like there is a direct short on the circuit. Before going any further, check other outlets on this circuit and make sure they do not have anything plugged in that is not expected and does not work. Check OUTSIDE your home, basement, garage, etc. as these locations require GFI protection - and may be fed from the bathroom outlet. After removing devices that are plugged into the circuit, attempt a reset of the breaker once more.
It is not likely that the circuit breaker has failed (but is a possibility). The outlet in the bathroom is probably a GFI type. You can determine this if it has "Test" and "Reset" buttons on it. You should be able to press the Reset button in fully even with power off. After resetting, you can attempt the resetting the circuit breaker as you have described above. If it stays on, try pressing the "Test" button on the outlet. Doing so should trip power to the outlet (and causing the "Reset" button to pop out) but leave the circuit breaker "On". If the breaker also trips, the GFI outlet is suspect and might need to be replaced.
At this point, a qualified electrician should be consulted to locate and clear the wiring fault.
Posted on May 09, 2013
  • sammy passmore May 09, 2013
    Thanks soooooo much for the help
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
Hair Straightener Brush Instant Magic Silky Straight Hair Styling Anion Hair Care Anti Scald Zero Damage Chornic Hair Straightener Brush Instant Magic Silky Straight Hair Styling...
Posted on Dec 16, 2016
  • 38 Answers
SOURCE: breaker
there is a live/neutral leak to ground or water contamination in the electrics
Posted on Nov 22, 2008
ccrozier_agr
  • 36 Answers
SOURCE: generator runs producing no power
Hi, remove the electric control panel & check the wiring as sometimes we have seen the wires coming off the voltage change over switches.
Also some of these units you can check the connections in the rear of the alternator & if it has brushes that they are not stuck.
Another problem we have had is the trip switches have went faulty but still switch operates ok, they need to be checked with a probe type tester for conductivety.
Posted on Nov 29, 2008
  • 244 Answers
SOURCE: generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Posted on Nov 24, 2009
  • 3 Answers
SOURCE: ok , im trying to
The meter at the pole should have a main breaker. At that point the neutral (white wire) will be bonded to the ground and connected to one or more ground rods. from the meter to your mobile home will be an equipment ground that should not be bonded to the neutral in the panel inside your home. The equipment ground from you panel going to the frame is bonding the frame of your home to the equipment ground.
Your large loads will be your Range, Clothes Dryer, Heat, Hot water. A good indicator will be your meter spinning rapidly (the horizontal disc) during heavy use. Turn off all circuits in the home and check that the meter is not spinning. If it is then there is another load other than your home on the service.
Posted on Mar 05, 2011
  • 3289 Answers
SOURCE: Home fuse box breaker issue
Hi Rex,
It sounds as if the upstairs bathroom outlet and the outdoor outlet are on the same circuit. There's a very good chance that these are GFI or "ground fault interrupter" type outlets, as these locations (and others) have required this type of protection for over 30 years. It was a common practice to run a circuit from the panel to one of these locations (or another) and then run from here to the next outlet and then on to the next. Since the GFI outlet could be purchased for around $10 instead of $30 for a GFI breaker, electricians would install outlets instead - both offered the same protection. A "regular" breaker would supply power to this circuit - but the very first outlet would get a GFI type outlet. It would be wired to the LINE terminals and the cable that feeds the rest of the outlets on this circuit would be connected to the LOAD terminals. If there was a ground fault condition, this GFI outlet would trip, but the circuit breaker would remain on. You would locate and RESET the tripped GFI outlet to restore power. The only time the circuit breaker would trip is if the circuit was overloaded. Overloads would NOT cause the GFI outlet to trip.
Now that you understand how it was typically wired years ago (and still a lot of times today), you should check all the outlets outside your home, in bathrooms, basements, garages, and inside your home next to doorways that lead directly to grade of your lawn or deck. These are required places for GFI protection. Press the RESET on any tripped GFI outlet to restore power. If the outlet will not RESET, there is a condition where the hot wire (black, red or blue insulated wire) is in contact with ground, or a device or appliance connected to the circuit has a problem. Unplug anything connected to the circuit and attempt to RESET again. If still unable to reset, open the outdoor outlet again and carefully pull it out and away from the box. Inspected for damaged or crushed insulation and repair / tape as needed. Before reinstalling, try to reset again. If it holds, trip the GFI by pressing TEST button. The RESET button should pop out. Reinstall the outlet and make sure the wires are not crushed or cut. Press the RESET button again. If it trips, you will have to remove the outlet again and take more precautions against damage to the insulation. it is also possible that the GFI outlet itself has failed, in which case it should be replaced.
GFI circuit breakers and outlets are supposed to be tested monthly by simply pressing the TEST button and then the RESET button. Replace any GFI device that does not test correctly if wiring and devices / appliances connected are OK.
I hope this helps & good luck! Please rate my reply - thanks.
Posted on Jan 12, 2012
Testimonial: "I firmly believe that Steve is correct. I plan on replacing the regular outlets with GFI outlets. Thank you Steve Rex & Shirley"
The fuse trips when the iron is switched on
dead short internally or bad wiring in the cord
cord can be replaced by electrician but otherwise junk it and get a new one
Dec 09, 2016 | Irons
What types of hair irons are there?
The main types of hair irons are;
Curling irons - they create a curl or wave in the hair
Straightening irons - flatten or straighten the hair
Crimping irons - create a look similar to crimps left after braids are removed.
Jan 10, 2013 | Health & Beauty
I have a steamfast steamer that is tripping the circuit breaker. Any ideas why?
you check the wiring inside which may have short circuit, then the connector for filament which get short.
Nov 28, 2012 | Steam Fast SF-661 Iron
Why do i get power at the 120v outlet but nothing works when its plugged into the outlet
It sounds like a bad neutral wire. Somewhere the neutral is not properly connected. Most residential wiring operates on a 240 single phase system comprised of two seperate 120 volt legs. Connect between either leg to the neutral gives you 120 volts.connect btween the two legs gives you 240 volts. If the neutral is not present the circuit will search out the other leg to try to complete the circuit causing dimming of lights extremely bright lights and all around chaos. Check ahead of the main to see that the voltage is correct. Check each leg to neutral with a voltage tester. Have some one turn some lights on and off while checking as sometimes a load is required to get fluctuating readings. If the reading fluctuate wildly the problem is between the power grid and the panel. If not recheck on a a couple of breakers and if the readings fluctuate it is on your side of the system.
. Hope this helps
. Bob
Nov 21, 2011 | CUTLER HAMMER BR4040B200V BREAKER CIRCUIT...
I've got 2 additions to my house; power to both went out last week. I have a tick tracer that I want to use to isolate which line from my panel goes to those additions (bathrooms) and is causing the dead...
If you have power out in parts of your house, look for a breaker or breakers that is/are tripped or if you have a fuse box, look there for blown fuse.
If no breakers are tripped, there is the possibility that you have a GFI in the circuit. Look for the GFI (google GFI if you dont know what im talking about) and reset it.
If an amp probe is what I think it is, it measures the amount of current going through a particular wire at a particular moment. If your power is OFF, or if you are not using any power on a particular line, the reading will be zero. I think you might be wasting your time with this tool.
If I misunderstood your question, please ask me again so I can try to answer again.
Thanks
a
Oct 02, 2009 | Measuring Tools & Sensors
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
No electricity in all bathroom outlets
you may have agfi outlet in the circuit. the outlet has 2 push buttons in the middle. it maybe an outside outlet that is tripped some contractors hook up the circiut like that
Mar 09, 2009 | Siemens Electrical Supplies
Iron causing electrical fuse to trip
I would almost definitely say yes. Have a friend or family member bring their iron over and try it. I can think of no other reason why it would trip a breaker. Let me know what happens.
Jan 26, 2009 | Tefal UltraGlide plus 1656 Iron
My hair straighteners will not come on. I have changed the fuse and this made no difference
see that happened to me u just have to thro it away and get a new one trust me it wont work again 3 of my family memeber r butician hair ppl or whatever salonist wehatevea u wanna call them so i get free straightener hair dryers and stuff so i dont have to worry :)
Dec 20, 2008 | Conair Professional Ceramic Hair...
Hammering Logo
1,169 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
