Question about Sport & Outdoor - Others
HOW TO PUT UP A NORDIC CROSS TENT MODEL:21.008-D
  • 2,994 Answers
Nordic Cross Tent Instructions
Not sure about the model but you may find the site useful
Posted on Jul 13, 2015
I'm trying to find the assembly instructions for a Columbus Homesteader model #1012 tent. Dimensions are 10 ft. by 12 ft
Slip the rods in. Peg out the 4 corners. Put the guy rope pegs in and tighten. Put the awning rods up and pin the guy ropes to those.
Here is a picture and a good review on Amazon
Columbus Homesteader 6 Person Tent
Oct 03, 2016 | Sport & Outdoor - Others
How do i put up a tent
Jo, you gave no make or model #, so Check the attached links,instruction and guides, the last link shows different type which you can google search for setup also.Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wilderness Survival How to Put Up Dome Tent
How to set up 4 man tent
Instructions for Putting Up Camping Tent
Types of tent
Apr 05, 2016 | Sport & Outdoor - Others
How do i know how to select a cross-country ski?
read here for some great tips on selecting a cross country ski
http://www.nordicskisource.com/Nordic-Ski-Selection-s/65369.htm
Feb 27, 2013 | Winter Sports
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    How to set up a spalding uv Tex 5 tent
    First set the 3 eleven piece poles with 2 crossed across the tent and one across the front portion. Feed them thru the channels and buckles. Then put the pin hooks into the bottom of the poles. You will need to arc the poles to get the pins into the end of the pole. Next put the poles that are smaller into the channels and buckles for the two vestibules. Again put the pin hooks into the same pole ends as the back crossed one.
    Stake the tent to the ground by driving the stakes thru the pin rings starting at the 6 corners of the tent. Pull front of vestibule taut and secure in place by driving stakes thru webbing loops at base.
    Install the rainfly by draping it over the top of the tent. Hook each of the 8 S hooks onto the provided loops. Secure the rainfly to the poles by wrapping the velcro straps around the poles underneath the rainfly.
    These instructions should be in the pocket on the wall in the main section of the tent in the pocket with red writing.
    Jul 03, 2011 | Rock & Ice Climbing
    I have a two man Ozark tent. How do I set it u p?
    Two poles. They pass up through the sleeves on the outside of the tent, across the top, through the sleeve on the diagonally opposed side, then each end is stuck into the pocket attached at each corner. They cross at the top. Then the small rain fly attaches with bungees over the top.
    Mar 03, 2010 | MSR Family Tents
    Instruction to put up a Coleman Rock Springs 4 Tent please?
    Wow, thats a monster tent. I'll get you most of the way there, but I may miss a thing or two
    Lay it down, stretch it out and peg it. That will save you a ton of time.
    Next, find the four longest poles. These are the supports. Two on each side of the door, crossing diagonally to the rear. Put one end of the poles in the holes and bend until you can get the other end in. These poles should slide through sleeves in the tent. Once these are up, the rest are "extras." The tent has hooks to hold the poles to the tent.
    You have two poles of equal lengths for the side windows. Again, route them thru a sleeve, bending them into the holes on either side of the windows. I can't tell, but it looks like you have a pole system for the front door too. Somehow these poles go next to the main support poles and meet up under the rain cover.
    Next, lay the rain cover on top of the tent. It should connect by bungies to the bottom of the pole support holes. There might be a pole or two under the rain cover, but above the tent for support. If so. look for a small pouch that a pole could slide into on the bottom side of the rain cover. You'll run the pole from the pouch to another pouch (all under the rain cover).
    Don't worry about strings or extra poles. These are for high wind. Pegging the tent down is good enough.
    Good luck
    May 22, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
    Convergence
    the coolant in the blue tube (CRT) needs to be changed thats why youre not able to see a clear blue. You can get the phillips coolant replacement kit at the following link which includes the coolant needed and a steop by step instructions with pictures CD. Heres the link.
    http://servicemanuals.vstore.ca/
    Aug 29, 2008 | Philips 50P8341 50" Rear Projection...
    Sport & Outdoor - Others Logo
    343 people viewed this question
    Top Sport & Outdoor - Others Experts
    Bill Eager
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
