Question about Apple AirPort Extreme Base Station
Network key i need the wpa key for my apple router
  • bavk Mar 28, 2009
    Hi
    My network key is already filled in with dots, and the "show key" box is grayed out. I did not put any network key in. How can I find out what it is?
    Thanks in advance.
  • bavk May 11, 2010
    My network key is already filled in and is hidden by those dots. The "show key" button is greyed out. How can I find out what the key is?
    Thanks in advance.
    Scholar:
  • 26 Answers
Hi gamejunky,
in order to get your WPA key on your router you will need to access your internal router configuration.  To do this you will need first your default gateway IP address, that is your IP address of your router.
If you are not sure what it is you will have to check your network settings, and under TCP/IP look for Default Gateway.
Once you have the IP enter it into your web browser address bar and hit enter.  You will then be prompted for a login to your router which should be default unless you set it.  The default is usually "default" or "admin" or "password" or some variation.
After this you should browse to your router security settings section and under WPA enter in a shared key.  Write it down somewhere safe, and you are done!
Hope this helps, and please take the time to vote!
Posted on Mar 13, 2009
Cannot connect apple ipod to wireless network
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the IPod, laptops and orcomputers with these router's wireless settings. Then the IPod, laptops and desktopcomputers can communicate with your wireless router.
May 17, 2011 | Linksys Wireless-G Broadband Router
Describe your NetGear Problem Cannot get Apple on line. Need to get WPA key? Comcaast states must go through you to get WEP key or password
I understand that you need to check the security key so as to connect the computer with the router's wireless network.
In order to get this key we need to login to the router's page using any computer which is physically connected to router. Please follow the steps on a computer connected to the router so as to check the network key:
1. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
2. Access the router's GUI by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase (or network key).
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the router's wireless network.
Mar 21, 2011 | NetGear WNR2000 Wireless Router
Where can I find the WPA or WPA 2 Key on my Cisco N?
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 19, 2011 | Cisco Linksys Wireless N Home Router...
Whats a wpa key? I have tried connecting to my router on my wireless device and my wireless device ask's for a wpa key? is it the same as a lan key?
WPA <<===>> WIRELESS PROTECTED ACCESS
You need to use an Ethernet cable to connect a computer to the router, and then access the web-server inside the router, and then run the "Wireless Networking Setup Wizard". When you do, you will set:
* the SSID ("network name") -- pick anything you prefer
* the encryption-level (hint: use 'WPA')
* the password for the network -- pick anything you can remember
Then, from a wireless device, do a "View Available Wireless Networks".
Select the SSID, and enter the password, to make a connection.
Feb 01, 2011 | D-Link DIR-615 Wireless Router
Is the PIN on the bottom of the router the same as the WEP or WPA?
WEP or WPA are the types of wireless security. If your wireless network is secured then there will be a password on the network that is called as wireless network key or passphrase ( WEP or WPA key ). PIN number is different than WEP or WPA.
To check the wireless network key ( WEP / WPA) you will need to access the router settings page.
On that page , you will find all the settings of the router.
Apr 29, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
I lost my wpa key number and have now reset the router - help!
You need to connect your computer hardwired to the router and reconfigure it. On your wireless computer, you need to delete all the preferred networks and add a new wireless profile.
Oct 06, 2009 | Apple AirPort Extreme Router
I have a apple. i want to put a password.. wpa security. how do i do this?? i have searched all over. the set up cd is only for pcs..
you want to put a password on wpa security...
here's what you do, actually you are going to open the firmware of your Wireless Router.
Open Internet Explorer, at the "search engine" just type the Gateway Address (192.168.x.x) then ENTER. After that will asking for Login: admin Password: admin __ this time your on the firmware of the Router. This time will appear and select for putting a password on wpa security. Hope this might you the steps. Good luck!
Aug 05, 2009 | Trendware TEW-432BRP Wireless Router...
I need my network key to add a new computer. I went to the belkin 192.168.2.1 page but which code is my network key please?
Hello...if you have logged into your router, you can find your network key by going to Wireless > Security on the menu.
If using WPA encryption, your network key is on this page: it will be labelled Pre-Shared Key or PSK according to the manual I have. Hope this helps.
(For info: the network key may also be known as the passphrase, WPA shared key, WEP key, WPA-PSK, authentication key, or security key).
Jan 26, 2009 | Belkin (F5D7230-4) Router (587009)
Changed router to airport extreme - no connection
bayoubill:
I am sure that Airports are WPA compatible. You manually put in the key of WPA or WPA2 in the router itself (in your case since you changed the router so please put in the key onto your aiport) make sure that this key matches the key onto the clients workstations or laptops.
Let me know.
Thanks
Dec 20, 2007 | D-Link AirPlus G DWL-G510 802.11g/b...
Archos 704 WPA/WEP
The WEP or WPA is the password to get onto the network. Think of the router as the doorman. The printer needs to get into the club so it needs the password otherwise it can't get access.
The WEP key and WPA passphrase are obtained from the wireless router or access point using the embedded web server on the router. See the documentation provided with your router to see how to access this information. Some routers provide more than one WEP key. Use the first WEP key if this is the case.
Dec 02, 2007 | Archos 604 Digital Media Player
Apple AirPort Extreme Base Station Logo
2,059 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
