Question about Jensen New Original MEDIA PRO 5000 Remote Control
Jensen media pro 5000
UNIT STOPPED WORKING. CHECKED FUSE, FINE. INPUT VOLTAGE TO UNIT GOOD. THERE IS A PINK WIRE OUT FROM PLUG NOT GOING ANYWHERE, CALLED12VDC TRIGGER WIRE????? ADVISE
SOURCE: jensen vm9510
Attach the pink wire to the red power wire to see if unit comes on. If does then no attached correctly to emergencing brake wiring.
Posted on May 16, 2007
SOURCE: Subwoofer just stopped working. There's power but no sound.
I have the same problem. My guess is that the subwoofer coil is messed up. You MIGHT have to get it recoiled. But before you do any of that get someone with a sub to play their sub in your car, if it works.... then your sub is messed up, if not.....then your amp is messed up ( trial and error ). Today i noticed my subs rubber surrounding is crooked, that may be the problem for me. Also when I press down on the sub it makes a sticking sound, like something came loose. So once i get everything opened and out ill let you all know the solution. Good Luck!
Posted on Apr 10, 2008
SOURCE: Having problems wiring a jensen vm8113 to my '05
any time I would wire an amp in my car I'd hard wire the power to the battery and the remote line would go to the fuse box ( cigg,acc,dome light, ect...)usually on the back of any after market head unit the remote line is blue or blue with a white stripe and most always it will have a connection crimped on the end.
Posted on Dec 30, 2009
SOURCE: Jensen AWM960 RV wall mount to replace my malfunctioning unit,
how too get second movie too activate on dvd..will only play the fir st on both sides of disc.
Posted on Aug 05, 2010
SOURCE: Jensen VM9311ts media module
I have the Jensen VM 9311ts. Where can I get a media module for it? I found the cord and the j link cord , but I can't find a media module anywhere. HELP!
Posted on Apr 22, 2011
Hello, I have the Jensen Media Pro 5000. System worked fine in October before winter storage in a building. Pulled the camper out to use in June and the system failed to turn on. There was a blue l
This is a common fault to almost all systems during winter. some of them even won't power up too. Contact any service technician. The internal wiring connection/s should be checked for proper contact with its sockets. http://electronicshelponline.blogspot.com/
Nov 14, 2014 | Jensen New Original MEDIA PRO 5000 Remote...
The pink wire doesnt go anywhere on my jensen mp 5000 in my cmping trailer
the pink wire is the switch wire for the parking brake which shuts the unit of whilst the parking brake is disengaged, if its disconnected then that should make the unit work all the time.
Check for loose wires on the red and yellow cables, also check the in-line fuse holder isn't loose.
May 10, 2012 | Car Audio & Video
My 86 Audi 5000 CS Turbo has quit running while driving but at stop signs or stop lights with no indication of anything wrong. When I try to start it again the battery is dead. I've bought batteries...
IF ALTERNATOR AND BATTERY BEEN REPLACED.REPLACE THE BATTERY CABLES AND CHECK ALTERNATOR FUSE AND CHECK ALTERNATOR POWER BATTERY FEED WIRE AND VOLTAGE REGULATOR WIRES FOR DAMAGE.
Sep 04, 2011 | 1986 Audi 5000 CS
How do i bypass the parking brake on my jensen vm8013hd
I just installed the vm8013hd and I simply grounded the pink parking brake wire to the chassis prior to connecting the power to the unit and it works just fine. No bypass box, switch, codes, etc. Good luck
Dec 28, 2009 | Jensen Car Audio & Video
No power to the spark plugs
Check first the wire connections to your ignition unit. Are they properly plugged? If all wires are good, try to measure the voltage from one of the wires to the ignition unit while the ignition key is in "on" position. If there's no voltage, have someone check your ECM. If there's a good voltage reading, try replacing your ignition unit with a good one.
Jul 10, 2009 | 1994 Suzuki Sidekick
I have a jensen media pro 5000 in my new camper and the dvd only played for 15 mins and now it doesn't turn any hints on how to fix
I had the same problem with the whole radio itself. It would play fine for about 2 mins and then it would quit and the blue backround would stay on the screen. I took it out of the wall and took the fuse out and put a new one in. It played fine for about 2 mins and then the same thing happened. The fuse was still good. Phoned the dealer and switched the radio. works fine now.
Mar 28, 2008 | Televison & Video
Jan 08, 2008 | Jensen VM9411 Car Video Player
Jensen New Original MEDIA PRO 5000 Remote Control Logo
62 people viewed this question
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
