2007 Indigo Manual
Rear wheel bearing
  • 3,799 Answers
I am not aware of an Audio card that has any kind of bearing, never mind front or rear wheels. If you are going to ask a question, I would suggest putting it in the correct section and actually asking a question. "Rear wheel bearing" is not a question.
Posted on Apr 25, 2013
Testimonial: "thank you for answering. when i filled in the questionnaire, it kept on coming up with audio cards, when all i wanted was to find out the number of the rear wheel bearing for my tata indigo. i could not get past the audio card!"
Rear bearings
As I said, all wheel bearings are replaceable. Remove the bearing cover, remove the split pin, undo the castleated nut, remove the hub. Push the bearing out from the rear. There is usually a small ring of bearing seat visible from the rear. I used to use a large socket with the extension bar and a good sized hammer with the hub on a block of wood.
Nov 24, 2015 | 2007 Kia Sorento 4x4
Can I replace rear wheel bearings only on my 2007 sorento [I realise I need to have them pressed in] or do I need to replace whole hub & bearing assembly its a solid axle type
Hub bearings are always replaceable using the existing hub. You only need to press them in by hand and then tap them in with a socket big enough to sit on the outer bearing race. Put the hub on the car, put the tire on the hub and tighten the hub nut whilst turning the wheel until the pressure on the bearing caused the wheel to lock up. Then back the bearing off by the required amount, usually a quarter turn. Check the manual.
How do I replace the rear end wheel bearing on driver side? It's a 2007 Crown Victoria. I was driving it to work one day and the back end locked up. It will drive forward but it makes the most horrific...
#1. A wheel bearing should not lock up the rear end. #2. Sounds like you have a far worse problem, probably in the differential. To replace the wheel bearing you need to remove the diff cover, take out the spider gear pin remove the locking c clip and remove the axle. Obviously the left rear wheel and rotor and caliper have to be removed as well. then the bearing ,which is pressed into the housing needs to be removed. If the bearing is that bad the axle will need to be replaced as well.
Feb 20, 2015 | 2007 Ford Crown Victoria
2007 ford sport trac rear wheel bearing replacement
Jeff is describing how to replace the front wheel bearings. In the front, the bearing is part of a "hub cartridge". Randy is describing how to change the rear bearings on a truck with a "dead" rear axle. The sort of differential which is one massive cast iron assembly from rim to rim. However, your truck has an IRS [Independent Rear Suspension] design. You need to remove the wheels, brakes & the complete rear knuckle assembly. To remove the bearing from the knuckle requires a hydraulic press and a "knife edge" bearing removal tool. I doubt that you have these tools available. If not, find an auto parts store or auto machine shop with these tools. They can press the old bearing out and install the new one for you. Then you can reassemble the knuckle assembly from that point on. The video linked below should help you.
Ford Explorer Independent Rear Suspension Rear Wheel Bearing and Hub...
With the knuckle off, you can easily replace the ball joints at the same time. Odds are you will ruin the original ball joints getting the knuckle assembly off, anyway.
Jan 11, 2015 | 2007 Ford Explorer Sport Trac
How do I inspect rear wheel bearing on a '07 MKX AWD? Making a growing noise.
Go on a test drive with a technician, visit a good workshop for a visual inspection on the wheels
Jan 01, 2015 | 2007 Lincoln MKX AWD
Are there any special tools needed to replace a hub bearing on the rear passenger side with E brake on a 2007 Impala?
Just a socket set. You remove the wheel, take the drum off (or the brake caliper and rotor if it's disc brake) and remove the 4 bolts on the back side of the hub. They are usually 13mm or 15mm 12 point bolts. You may need to tap it with a hammer to get the bearing assembly off of the axle. That's it!
Nov 24, 2014 | Timken 2007 HA590092 Chevy Impala Rear...
Tata indigo 1.4dsl
Sorry we have no diagrams or manuals.
May 25, 2014 | 2007 Tata Indigo 1.4
How do i remove a seized up rear wheel bearing on a 2 wheel drive 2007 Chrysler Pacifica Touring
How do you know its the bearings.
Aussuming the car is front wheel drive, what happens when you try to drive it? Does it drag the wheel? There is a chance it may break it free since you've gone over it with a slege hammer.
Mar 12, 2014 | 2007 Chrysler Pacifica Touring
How to check rear wheel bearings 2007 jeep compass
block front wheels and jack up rear slightly off the ground, keeping your body parts out of harms way you can grab and shake tires, if they move back and forth or in and out even slightly it is time for bearing work
Nov 23, 2012 | 2007 Jeep Compass 2.4
Honda Civic 2007 Civic . Cahange wheel bearing and
sorry to tell you this but it sounds like the wheel bearing was put in backwards on one or both sides. the front wheel bearings have a black speed ring built in and that is what your speed sensor reads off. - this is common as the front bearings will install either way- hope this helps
Dec 12, 2009 | 2007 Honda Civic GX NGV Sedan
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
