Picture frame is not centered on the tv screen
    Top Expert:
  • Televison & ... Master
  • 74,468 Answers
You must get into its service mode, and do convergence and picture centering adjustments. Really it is a skilled work. But, if your are sound in electronics, you can do it by yourself. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window. Convergence and other adjustments to many brand PTVs are give in detail with illustrations. Pull up older posts there.
Posted on Apr 25, 2013
Sony tv troubleshooting
Hi, Please try to push or move the frame of your tv set on the dark side of the picture. If the picture becomes normal it is the loose connection. Otherwise it may be panel failure. Please consult some qualified technician or the service center.
May 04, 2014 | Televison & Video
Heard loud popping sound with tv off. When I turned it on the picture stretched across screen with a dip in the center. Started ~ 4 months ago. The video picture does not show centered on screen(the...
Sorry the problems u have is not for hobbiest or amature to do.High voltage Deflection board areas.This problems,must have experience tv tech to troubleshoot and replaced parts or boards require for the tv.Could be extensive repairs or just requiring test and replaced some of many small capacitors,resistors,transistors and ICS.Have to do major troubleshooting though.Must get priced quotes by many big screen tv shops,than u decide,which to give the job to.
Dec 09, 2010 | Samsung 50" Slim-Depth DLP HDTV
Coloured lines on screen
Make sure first that the picture is centered by using the remote control to move the picture vertically and horizontally. Use the round pad towards the center of the remote and push the button according to which direction you want the frame to move.
Sep 10, 2009 | Philips 42 in. Plasma TV
Screen has borders when watching tv
This is common issue of the channels that use 4:3 format while TV is designed for 16:9. To get it disappear, you just go to picture option, choose WIDE FIT, this fuction will widen the picture to whole screen. Of course, you have to accept the picture is blur a bit.
Aug 14, 2009 | Samsung LN32B360 32 in. LCD HDTV
I have a toshiba 50inch rear progetion tv. I was
There is one mirror inside. It is easy to remove the front plastic screen by removing the bottom fabric grill (snaps off by pulling outward like a removable speaker grill). Remove several wood screws along bottom edge of screen. Lift up the whole plastic screen frame and pull it away from the TV; but be careful with the control wires that go to the center panel, which snaps off the big screen frame easily. The mirror is right there.
Apr 01, 2009 | Toshiba TP50G60 50" Rear Projection...
No picture on full screen.
its proably worth repairing as long as the tv isnt 20 years old
Jan 15, 2008 | Samsung PCH521R 52" Rear Projection...
PICTURE IS ONLY FINE HORIZONTAL LINE
Hi there,it looks as if you have a frame collaps,this is the first time i have ever heard of this on an LCD tv,i take it that there is no picture at all only a thin line.
Dec 23, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Standard CRT Toshiba TV - 4inch tall picture in middle of screen...
Not familiar with your actual model.
But a comon problem with older Tosh sets is the 2.2uf electrolytic caps from memory they are usually red there is 1 next to frame Ic & the second is near Psu.
Allso check frame o/p IC for dry solder joints this is easy to test for.
Tap the tv while it is on if the the frame suddenly pop to full size picture you know its dry joints so resolder frame IC.
http://dysonmanuals.inc.io/
Oct 13, 2007 | Televison & Video
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Sep 06, 2007 | Toshiba 32A60 32" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
