Question about Cuisinart EM-200 Espresso Machine
Water will not come through.
When I try and make an espresso it seems clogged the water will not come through. I have cleaned it to the best of my knowledge, I have made sure that the water tank is securely on the base and I have cleaned and checked that there are no clogs in the espresso coffee holder. It has been working fine and then it made a really funny sound and no more coffee. It is not making the funny sound anymore just not producing the coffee. I am not sure if the brand is the EM-200 or not. It is not an automatic. It does have a steamer on it.
    Sergeant:
    Champion:
  • 234 Answers
Is the water hot? If you have hot water then I would ckeck for a solnoid valve to see if it stop up.
Posted on Mar 13, 2009
Astoria sae 2n . the lights stay on. They do not flash. Nothing comes out of the heads but water did come out of spouts that are located directly behind panels. There seems to be one for each espresso head...
Has the machine been cleaned / descaled? Coffee machines become clogged with mineral scale deposits from the water. Some folks use citric acid , about two tablespoons /qt of water, and some folks use white vinegar, 1/2 & 1/2. Place the solution in the machine as if you were making coffee. It may take a few cleanings if there is a lot of deposits. After cleaning dissolve two tbsp of baking soda in a quart of water and run through machine to neutralize the acid.
May 13, 2014 | Coffee Makers & Espresso Machines
Went to make a cup and only got about a qt. of a cup. tried again and got no water at all can you help
I own a Jura Capresso S8 espresso machine which has been wonderful except for the pump that makes the froth. I sent it back to be repaired once already, at the tune of $250.00. Now it seems to have gone again, and this time it will cost me $275.00 to have it repaired. Anything I can do myself?
Aug 14, 2009 | Jura Capresso C1000 Espresso & Coffee...
Why are my ejected coffee pucks very wet? Seems
You need to be sure the removeable grinding surface is clean and not clogged. If it is not clean, water has problems passing through the screen and the water cannot escape, staying in the puck...
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Water flow problem
Check the coffee chute to see if its clogged. It is easier to use a small amount of white rice to clean your grinder, about a teaspoon.
Feb 22, 2009 | Solis Master 5000 Espresso Machine
Rinsing the incanto
If you will clean it after using a preground coffe, open the door and take out the brewing unit (central unit) and wash it in warm water instead.
Make sure to descale your machine regularly.
Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Espresso Flow Problems
Thanks a lot 20pence! - i removed the disc as described, cleaned it and this solved the coffee flow problem - I also had a problem with hot water coming down the steam pipe even when the valve was closed - presumably the disc was so clogged, the water was forced back down there. After cleaning the disc this does not happen - thanks again - good advice
Dec 04, 2007 | Dualit 84024 Espresso Machine
No water ever makes it through the pump
I just got mine working again. There was scale in the outlet port for the coffee basket.
Try cleaning by running through a solution of CLR and water (1 to 4 parts) and keep running until the blockage dissolves and flow is restored. Then run another solution again just to clean it for good.
MAKE SURE TO RINSE OUT THE RESERVIOUR VERY WELL. Should run clear without foam after about a gallon of clean water.
Nov 22, 2007 | DeLonghi EC701 Espresso Machine
Cuisinart EM-200 Espresso Machine Logo
1,221 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
