Question about Drills
54-2986-4 hammer drill brush repacement parts
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
comax
  • 154 Answers
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Posted on Apr 13, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
SOURCE: I have an AEG hammer drill that no longer hammers.
service manuals AEG SB2E-1001
Posted on Feb 26, 2010
  • 123 Answers
SOURCE: drills but dont hammer te 74
Hilti no longer carries parts for the 74. However most of the TE75 parts will interchange with the 74
Posted on Apr 03, 2010
I need 2 carbon brush for a 1/2 hammer drill model 94436 brand drill master.
http://manuals.harborfreight.com/manuals/94000-94999/94436.pdf
The link above is for the manual. There is a phone number at the bottom of some of the pages for technical assistance. Harbor Freight tools are sometimes difficult to get parts for. Either that or you can take the drill to a small tools repair shop and see if they can match the brushes up.
Oct 17, 2017 | Hammer Drills
Makita hr3851 won't hammer or drill
Try pulling out the brushes and blow some air in were the brushes go it may have gotten some trash in between the brush and the armature . they may need to be replaced, here is a pleace that will give you a breakdown and sell you the parts. http://www.ereplacementparts.com/makita-hr3851-rotary-hammer-parts-c-97_380_491.html
Jul 30, 2016 | Makita Drills
How do i change brushes on bosch 11227e hammer
  • A big allen wrench and the 6 screws of the handle sometimes its enough to cleanout the brushes only the hanging on dust sometimes , the grey plastic
    switch slide unmount from the underside with a little screwdriver to remove the 2 screws behind .
Bosch 11227E 0611227139 Hammer Drill Parts
Aug 01, 2015 | Bosch Drills
Carbon brushes panasoni 14.4v
part ordernumber = WEY6432L1008 pos 26 you may have to order that MOTOR because there are no individual brushes to buy to replace is not possible ,, this motor has hammer brushes inside a complete closed motor. .
Nov 06, 2012 | Panasonic 15.6v Ni-mh Cordless Drill -...
I have a TE 60 hammer drill. It does not run . I looked at the brushes and they are wore .One of the wires to the brush is broken. Can you inform me on how to get replacement brushes?
If this is an older metal housing TE60 parts are no longer available. If the brushes are worn out then the commutator on the rotor is also probably worn. If it is a new version of the TE60 (introduced in 2009). Then parts are available for it.
Contact Hilti @ 800-879-8000
Nov 16, 2010 | Hilti Drills
Where can i find brush's for a TM75VSP hammer drill
You can call Hilti @ 800-879-8000 to see if they still carry parts for that model. It is actually a TM7S VSR.
Before buying brushes I would check the commutator segments to see if they are burned. Most times on that model if the brushes were bad then the armature was also bad.
If Hilti no longer carries parts check with Metabo. They manufactured that model for Hilti.
Mar 09, 2010 | Hilti Drills
Fixing the springs to the carbon brushers to a 24v battery bosch drill
The brushes come as an assembly with the spring and brush in one unit. If your springs are bad you can order a set of brushes. The part number is 2607034901 and they run around $6.50. If your springs are melted looking there may be an underlying problem with the motor, mainly that there is a short in the motor or even switch. If the brushes are just worn and not touching the commutator bars then it is safe to just replace the brush set and you should be ok. Any questions please post back.
Oct 12, 2009 | Bosch 13624 24V Cordless Hammer Drills
Mastercraft 1/2'' hammer drill not working
Some of the 'good' hardware stores sell small brushes for hand tools. Look around and you can custom fit the brush if it's not exactly right size with light sand paper
Oct 01, 2009 | Drills
Hammer drill quit
If it is an 1199, forget it. Replace the brushes and do NOT use for hammering. It is a design problem. My unit was repaired 4 times and hammered about 5 holes each time before same failure.
Jul 02, 2009 | Bosch 1617014127 Brush Set For 11224vsr
Drill just stopped? not working
These tear the brushes out. You can not use them for hammering. It is a design problem.
Replace the brushes and use only for straight drilling.
Jun 28, 2009 | Bosch 1199vsr 1/2'' Dual Torque Hammer...
Drills Logo
66 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
