Question about Sharp FO-DC535 Fax
Main motor error - Sharp FO-DC535 Fax
What is error e3?
http://www.how-to-repair.com/help/sam...
This video will show you how to identify your 3e error code fault and replace the motor or carbon brushes
3E error code is a Motor tacho fault detected
Can also be caused by be main PCB
If the motor tacho signals are inputted less than 2 for 2 seconds after main drive motor started, this error will occur on normal brush motors and direct drive motors
Check carbon brushes if fitted
Check motor capacitor
Check motor
Check motor tacho
Check all connections and blocks to the motor
Check connections on the main control module
Check main control module
Aug 22, 2016 | Dishwashers
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Mar 09, 2015 | HP Office Equipment & Supplies
Erro 59.00
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor's cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Sep 15, 2013 | HP LaserJet 4345mfp Printer
Error 59.0 A motor error
59.X PRINTER ERRORA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor's cable to ensure that it is seated properly. 4. If the error persists, replace the main motor
Jul 13, 2013 | HP LaserJet 5100 Printer
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
I have a new hp laserjet 4015x that keeps giving me an error code 59.00.
Thank you for contacting FixYa with your printer inquiry.
59.xx is usually associated with a main motor startup error. A main motor error occurred.
Actions:
  1. Power cycle the printer by turning the printer off and then back on. Listen for motors.
  2. Open the printers back panel and remove the fuser. Check for paper jams then reseat.
  3. Check the toner cartridge and make sure nothing is hindering movement in the gear train.
  4. Check the main motors cable to make sure it's seated properly.
  5. If the error persists then replace the main motor.
Parts Info: http://partsurfer.hp.com/Search.aspx?SearchText=CB511A See Motor Section.
RL1-1657-000CN - Main drive motor (M101) - Drives the tray 1 pickup roller, tray 2 pickup roller, and feed roller.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Aug 26, 2010 | HP Laserjet P4015x Printer
How can i fix hp3600 59.Fo error
59.X PRINTER ERROR A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Apr 21, 2010 | HP LaserJet 3600n Printer
How do i fix a 59.90 error?
Mar 19, 2010 | HP LaserJet 3600n Printer
I get a 59.4 error trying to print with the 2840
The problem is not the fuser, is the main motor, you have to change it
May 26, 2009 | HP LaserJet 3600n Printer
57.70 error for hp colorlaserjet 9500n
this is the fuser fan error replace them ur problem will be resolved
Nov 25, 2008 | HP LaserJet 9500n Printer
Sharp FO-DC535 Fax Logo
18 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
