Question about Dishwashers
E4 error code in powerpoint IDW8. Water inside base. When moped up m/c operates for a short time and then stops , repeating the E4 error code.
3 Suggested Answers
SOURCE: Dishwasher problem powerpoint IDW12
clean the filter on the intake pipe, just done mine.
Posted on Dec 02, 2008
mrsno
  • 166 Answers
SOURCE: Powerpoint dishwasher IDW12 is displaying
Hello there.
This is a well known fault with this particular dishwasher, error E4 and the audible alarm means you need to contact whoever you purchased the dishwasher from and ask them to repair it.
It needs serviced.
Hope this helps.
Posted on May 24, 2008
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
May 31, 2011 | Kenwood Dishwashers
Whirlpool Accubake Range - error F6 E4 , how do I stop the beeping
Replace the sensor as shown in the F6 code
F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC)
Error Code: E4
Cause: Shorted sensor
Example: Disables cooking in affected oven
Corrective Action: Check sensor
Nov 02, 2010 | KitchenAid KESC300 Electric Kitchen Range
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
Apr 28, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Base unit displaying E4 after we experienced a power black out
e4 error code that means it ihas defective base unit. it happened due to a spike in the power lines that may cause this error
Feb 09, 2009 | Uniden 5.8GHz Cordless Phone
Error code e4
This might be a re-badged generic dishwasher - on my Baumatic E4 error caused by floatswitch in bottom catch tray. Some (supposedly small amount) water collects here and should evaporate naturally. If it accumulates, float rises and stops machine.
TURN OFF THE POWER
try to find a way into the machine base catch-tray to sponge it out - on the Baumatic there are two large black plastic plugs on the front of the machine base that can be forcibly flipped out.
failing that, take machine out and tip it up to get rid of water
Oct 09, 2008 | Maytag Dishwashers
Apr 02, 2008 | Dishwashers
Hoover dt999
E4 means that water is not discharging properly, check the hose, filters etc
Mar 30, 2008 | Hoover 24 in. DT999 Free-Standing...
Beumatic
The E4 code means - Overfilled. To much inlet water. Remove water manually from the tank pan and try operating a new cleaning cycle. Good luck !
May 31, 2007 | Baumatic 23 in. BDW14 Built-in Dishwasher
Dishwashers Logo
283 people viewed this question
Top Dishwashers Experts
