Question about Maytag MDE308DAYW Electric Dryer
Complete manual, squeeky noise then shuts down
Need complete service manual of unit. How does cabinet come apart? Where are the belts? Where is idler pulley?
  • Maytag Master
  • 7,482 Answers
Hi
Hi Harold
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
For a breakdown on your dryer go to the following webpage.
http://www.partselect.com/ or
Please take time to rate me
Bud
Posted on Apr 25, 2013
SOURCE: drum belt tension
I found a dryer manual on the web that showed how the drum belt wrapped around the pulleys.
Problem solved.
Posted on May 12, 2009
Illeagle
  • 525 Answers
SOURCE: need idler pulley wheel - with arm. mod# p
Provided, courtesy of www.repairclinic.com
You can find the Idler pulley on this page;
http://www.repairclinic.com/SSPartDetail.aspx?s=t-+mde9316ayw+-%3d%3di1472812&PartID=1472812
You can find the idler arm on this page; http://www.repairclinic.com/SSPartDetail.aspx?s=t-+mde9316ayw+-%3d%3di1472858&PartID=1472858
Posted on Jul 14, 2009
BIKER T
  • 909 Answers
SOURCE: idler spring came off when belt broke, not sure
Takes patients but can be done. First place idler arm in position then connect spring. Try and hold firmly while you place belt through pulley and fold around motor shaft. If installed right ,the pulley will maintain a constant pressure on the belt.
Posted on Sep 27, 2009
  • 744 Answers
SOURCE: Dryer is making an extremely loud squealing noise.
Turn the power off to the dryer (unplug it).
The back of the dryer will have to be removed. Then disconnect the drive assembly and start checking the pulley components. I have included a picture for a Maytag dryer belt routing below. If it is the idler pulley, it will be the pulley shown just below the motor pulley.
If it turns out to not be the idler pulley, it may be one or more of the drum support pulleys around the drum, so check those too. This would also be a good time to check the belt.
Posted on Jan 06, 2010
marka19
  • 1430 Answers
SOURCE: Maytag DE303 dryer installing the drum belt
No don't lube the idler pulley replace it. There are videos at www.appliancehelponline.com/servicemanual.html that can walk you thru the disassembly and also on replacing the belt. You can also enter in your model # for diagrams and illustrations.
Posted on Apr 09, 2010
Squeeky noise coming from engine
Sounds like the belt is too loose. It slips and the alternator stops turning and the light comes on. Look online on "how to" adjust the belt.
Good Luck....should be a simple fix.
Mar 02, 2014 | 1996 Geo Prizm
Lasko tower
it will need the bearing changed. you can get copper bearings off ebay you just need to know the size or motor number.
Sep 28, 2013 | Lasko 2115 Wind Tower Fan
Squeeky noise while aircondition is on
I would check the A/C belt for cracks or glazing on the belt, you may need to replace that belt.
May 22, 2010 | 2003 Honda Civic
Ge microwave starts but motor noise
You will need to replace the motor. It no doubt has bad bushings. Unplug unit. Remove all the screws from the rear of the unit case, perimeter and slide the cover off to the back. The motor should be visiable at this point. Go to http://www.repairclinic.com where you can get the new motor. The mounting procedure should be obvious, either two or four screws. Remove and replace the motor. The motor wires should be spade lugs. Remove and replace one at a time to avoid any confusion. Reassemble the unit and you should have a quiet running microwave. Let me know if you need more help. Thanks for using FixYa and for the generous rating.
hardrocko
Apr 09, 2010 | General Electric Microwave Oven
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Squeeky Noise
Raise top by prying lose clips on front, remove 2 screws holding front in place (inside cabinet) and disconnect wirings, removed front (panel with door) panel, removed 4 screws holding inside front panel in and lifted it out, released tensioner from belt, lifted out drum out of unit, vacuumed accumulated lint from machine, motor, wiring, checked and greased drum rollers and tension pulley, cleaned drum edge from accumulated roller debris using automotive brake rotor cleaner, reintsalled drum, applied automotive belt dressing to belt and reassembled. Working for now. If reoccurs I will replace drum rollers and tension pulley.
Nov 22, 2008 | Maytag MDE4806 Electric Dryer
Belt Noise for Chamberlain HD600 1/2 HP Whisper Drive Garage Door Opener
You could always use "Belt Ease" from an Auto Parts store. It's made for squeeky belts.
-Lonnie
Jul 29, 2008 | Electrical Supplies
Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
Apr 29, 2008 | Sony TC-WR565RM Single Cassette Deck
Maytag MDE308DAYW Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
