Question about Toys
Toy Manuals Where is the battery compartment??
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
The battery compartment in what make and model toy?
Posted on Apr 24, 2013
FurReal Lulu kitty batteries corroded and rusted battery compartment. Can compartment be repaired/replaced?
You have to clean the contacts that touch the battery with a metal screwdriver, rub them until the metal shines.
Dec 21, 2013 | Tiger Electronics Toys
Batteries carroded . It will not respond .
Read this article about how to remove corrosion from battery compartments: http://www.ehow.com/how_5386483_remove-battery-corrosion.html If you are able to remove all of the corrosion, you might be able to insert new batteries and get the toy working again but it can be very challenging to find and remove all of the corrosive acid so if the new batteries don't work, you'd have to take the toy apart, and possibly replace the contacts in the battery compartment.
Mar 05, 2011 | Toys
I replace the batteries in the remote control and the train will not go. Is there batteries in the train that might need to be replace, if so, where do I find them?
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine. • Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries. • Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten. • If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
Feb 28, 2011 | Fisher Price Geotrax Remote Control...
How do you replace the battery in the Hasbro IronMan2 walking toy?
Battery compartments are located on the bottom of the feet. Access panel removal requires the loosening of ONE screw on each foot. Each foot accepts two double-A batteries. Do NOT remove the back of the toy.
Feb 07, 2011 | Hasbro Iron Man 2 Radio Control Walking...
How do you change the batteries in BUzz?
The compartment for the battery is located at the back of buzz. You have to unscrew using aa small crew driver to open the lid before cahnging the batterie.
Nov 13, 2010 | Thinkway Toy Story Buzz Lightyear Space...
How do you put the aaa battery in the happy hamster
Turn the hampster over so that the battery cover is facing up. Then unscrew the battery cover. It is the screw in the top left corner of the hampster. This is the only screw that you remove from the hampster. Do not remove the screw that is next to the on/off switch! Once you have removed the right screw, pull the battery cover off. Then you need to remove the whole battery compartment from the hampster. Do not be afraid of damaging the toy, because the plastic undercarriage of the toy is held in by velcro. Turn the battery compartment over. The actual compartment where you put the AAA battery is on the opposite side of the hampster undercarriage. You will need to then unscrew the battery flap and insert 1 AAA battery. I hope this helps!
Oct 24, 2010 | Toys
I need to know how to replace batteries in a vintage buzz lightyear cant find a battery compartment
Unscrew the screws on his back. This will allow you to remove the wing assembly. Under the wing assembly is the battery compartment.
Jun 14, 2010 | Radica Girl Tech Video Journal
How do you replace the battery - the compartment seems to be sealed
The compartment is glued shut. If you do force it open, you'll find that it is empty. No batteries have been wired into the battery compartment. It must have been used in another model - but not this one.
Feb 21, 2010 | Mattel Barbie 2008 Glamour Jet Plane...
Toy can't work after changing battery
Make sure that ALL the batteries are good, right size and voltage and are the right way around in the battery compartment.
Dec 11, 2009 | Seth Thomas Toys
Put new batteries and it won't come on
There are a number of possible reasons your toy may have stopped working. Sometimes it helps to clean the battery compartment with a dry cotton swab or cloth. Rub the gold contacts inside the battery compartment to release any dust or film. You can also use an eraser to 'erase' and clean the contacts. Once you have cleaned the contacts, please make sure to install new non-rechargeable batteries before turning your unit on.
If the toy still does not work, it may have been dropped or handled improperly
Jul 28, 2009 | LeapFrog Leapster Learning Game System
Toys Logo
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
