Question about Briggs & Stratton Garden
Blowing gas out carb - Briggs & Stratton Garden
    Sergeant:
    Champion:
  • 320 Answers
If its an OHV engine you will need to check the valve lash setting to see if they are correct. You most likely have an intake valve problem.
Thanks; George
Posted on Oct 18, 2013
Why does a 2cycle chainsaw blow gas out the carb.
possible cause is that the muffler is carboned up and producing excessive back pressure
Apr 23, 2016 | Garden
Why is my chainsaw blowing gas out the carb?
If it is blowing an excessive amount of fuel while it is running then the cylinder has aprobably worn down and the tolerences are bigger than they should be therefore you are getting fuel back out the carb. If it is leaking while shut off then you have a needle not seating in the carb correctly
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Feb 10, 2015 | Husqvarna 141 142 136 137 Cylinder Piston...
I have a problem with my electric generator (don't start ) i allready replaced the sparkplug and new gas and still doesn't start (chicago electric 5500 watts)
did you blow out old gas from gas line going to carb? if this generator set up over the winter with no use, it probably has water condensation in the gas tank which has gotten into the gas line and carb. If you didnt do it already, blow undo the gas line off the tank and use compressed air (or by mouth) to blow out all the fule out of the line and carb. If you did not drain the old gas out before adding new gas, there still may be water in the tank and line. Try this and see if it fixes it. Give it time for the new gas to get through the line to the carb. To avoid this, keep the fuel tank full especially over the winter and you will not get any water condensation.
Mar 28, 2011 | Garden
I have gas leaking out of the overflow, and it wont stop running out.... all the gas dripps till empty...need t o know if its the gas knob that wont cut the gas supply or if its the carb..
with tank empty and knob in the on position blow into tank air should flow turn knob to off position blow air should not flow . if knob passes lightly tap carb . the float might be stuck
Feb 21, 2010 | Cycling
Gas is not going thru the engine
it all starts in the carb...
most problems with starting usually always start in the carb..i get dirty cleaning everything and often hook a dry hose up and blow through my holes in the carb...even blowing the jets...
if you cant blow air through it...you aint blowing gas through it
Jul 18, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Have to start on starting fluid, won't stay running. have replaced gas line and filter and primer bulb. What next?
You will have to pull your head to see if the valves are seating. If the exhaust valve is not seating it will send blow back through the carb.
Jul 17, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
32 cc blower not starting
your problem is inside the carburator.there is a small screen inside that needs to be cleaned out.take the single screw from one side of carb.there is a small screen in side.carefully take an air hose and blow it out.do not blow to hard or the screen will blow out.once it's clean the unit will start right up.hope this helped,let me know.................................
Jun 29, 2009 | Craftsman 4 Cycle Blower/Vac
Blowing gas out the air intake
Eight years is great for a weedeater! Blowing out can mean something is stuck in the reed valves, or one may be broken. They are just under the carb, usually. Be real careful with the gaskets. If you mess up any, silicone will do. Use good car gasket silicone.
Apr 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
41 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
