Panasonic AC Model CS-A28BKP5 remote not working.
Remote does not work....Replaced with a new remote however still no joy. Checked remote and is functioning correctly ....unit can be turned on and off manually...does this mean the sensor on the wall unit needs replacing?
  • frandercus May 07, 2009
    Panasonic AC Model CS-A28BKP5 remote not working, I have tested the remote and it works fine. I have also tried a second brand new remote control with the same result. The AC otherwise turns on ok manually.
Order new remote
Posted on Mar 14, 2009
Where is the infrared receptor card in this equipment to change it. I have a split ac panasonic CS C24BKP and does not respond to remote control. I know the remote control is good because I saw thr...
There is a receptor on the below the front pannel but the problem could be :
1.Low battery charge in the remote control.
2.The signal cable that connects the receptor to the card(pc board) could be loose/disconnected
3.Try one receptor from a working unit
4.Try a remote control from a working unit
Regards,
Adamson
nyauadamson@gmail.com
May 02, 2014 | Heating & Cooling
Panasonic cs a90ke
Try cleaning off the sensor on the A/C (where the remote signal is received )
Aug 30, 2013 | Heating & Cooling
Panasonic AC Model CS-A28BKP5 remote not working. Remote does not work....Replaced with a new remote however still no joy. Checked remote and is functioning correctly ....unit can be turned on and off...
If receiving signal in unit and calling signal in remote should be functioned properly. If any one of these, defective you can't operate by remote.
In your case, it's receiving signal in PCB is weak or defective. You can repair/replace only that portion. Call repairman to arrange for it. Thanks. Helpful?
Jan 20, 2011 | Heating & Cooling
Panasonic CS-W24DKR/CU-W24DKR not responding to remote control
to easily test remote,turn mobile phone camera on and operate remote with infe red end looking at phone camera,if remote is working you will see a white light on camera,if u get a light on camera reciever in wall unit may be faulty.
alan @zia airconditioning.
good luck
Jul 15, 2010 | Panasonic Heating & Cooling
Remote does not turn on Panasonic CS-A28BKP5
Point the remote control IR LED at a digital camera such as your phone camera (The LED is usually on the top of the remote and is what is used to transmit a signal to the receiver board on the head unit). When you press any button on the remote, a purple flash from the LED should be seen on your camera screen. If not, you have a faulty remote. If you see one, you probably have a faulty receiver board and will need to replace it.
May 11, 2017 | Panasonic Heating & Cooling
Cyberhome 20'' lcd tv-dvd remote control not working
Not sure on your model, but if it's Model XC8810, I found the code 0794 (NZ) for it whilst I was trying to find a replacement remote for my Cyberhome LT0150-A Flatique : )
Hope it's of some help.
Device Type Brand Model OFA Code Comments LCD TV DSE G3810 1497 LCD TV CyberHome XC8810 0794 Device Type Brand Model OFA Code Comments LCD TV DSE G3810 1497 LCD TV CyberHome XC8810 0794
Apr 03, 2009 | Cyberhome CH-LCTV 150 15 in. LCD...
Panasonic DMR-ES10 DVD Recorder
You can, indeed! It is probably made by Thompson, so try codes 10, 15 or 44: while pressing the power button on the remote, enter the appropriate code. Test to see if it works by trying to change channels with the remote. If no joy, try another code. If no joy with any code, come back to me and we can try to identify your TV model and take it from there.
Mar 04, 2009 | Panasonic DMR-ES10 DVD Recorder
Remote control
Check this remote on other set but samiler model and confirm that is some thing wrong with remote or set.
May 27, 2008 | Sony RM-X140 Remote Control
Sony Vaio VA1 remote not working
Hi, If you've got a webcam, you can do the following. Turn on the webcam and point the remote at the webcam. When you push a button you should see a light coming from your remote on your screen. If not, your remote is broken.
Mar 03, 2007 | Sony VAIO VGC-VA11G PC Desktop
Heating & Cooling Logo
347 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
