Question about Boston Acoustics Recepter Clock Radio
Dead radio works for about 10 minutes then gets reals static and no sound . after shutting off for 5 mins and turning back on it repeats the cycle
The heater runs for a few minutes and then it turns itself off it's on stable ground and everything
My furnace keeps shutting off, only runs for about 5-10 mins ...
? 5:19
https://www.youtube.com/watch?v=pEng9mtBtKk
Dec 15, 2013 - Uploaded by shannon122005
My furnace shuts off before reaching the set temperature on the... and then i turn switch back on , the furnace running about 4-5 hours and then ...
Furnace starts, then shuts off. - Home Improvement ' DSLReports Forums
www.dslreports.com > ... > Home Improvement
DSLReports
Dec 1, 2009 - 30 posts - ‎18 authors
[HVAC] My gas furnace cycles off every 6 minutes. ... This cycle will repeat a fewtimes, then usually after the second or third time everything ... How long is it after the big blower cuts on that the gas shuts off? ... Turn the furnace on, once the inducer blower is running you should read 0 volts (switch is closed).
Jan 03, 2016 | Heating & Cooling
Brand new Wel Bilt 1 HP shallow well pump, shuts off after running for 5 to 10 min !!! Help ! JGP12001CHT (Northern Industrial Shallow Well Pump. Installed to pump creek water for yard, runs at 30 PSI on...
It sounds to me like you have a defective thermal switch that is shutting power off as if motor is overheating.Unless you are exceding the head or flow ratings on the pump I would recommend you return it for replacement.Thank you.
Jul 13, 2011 | Plumbing
I have a bose lifestyle 12 and we get a static sound with a pop and the sound goes dead. If we turn the unit off and back on, it works for 10 minutes or so then does it again. Sometimes it will go for...
It could be bad soldering joints inside the unit. If the unit is moved and comes back on then it will be definitely that!
Otherwise it could be some device which is heating up due to failure and shuts down when it gets to much. When it cools down it starts working again.
Jul 18, 2017 | Bose Lifestyle 12 System
Sylvania LC320SS8 32 in. LCD Television - Will not turn on
U have power on 10 mins,than is not the power supply board.Ur Tuner board is dead replaced that board.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish tuner signal board.
Feb 09, 2010 | Sylvania LC320SS8 32 in. LCD Television
The engine stops running after 10 minutes of driving
could be a bad crank sensor, a bad crank sensor will let car run for a while then shut down and will not start for 10 to 15 min. and it will repeat this cycle if not fixed.the crankshaft position sensor provides the ignition module and pcm with a crankshaft position signal. the module uses this signal to determine spark for each cylinder. the pcm uses this signal for proper timing of engine.
Dec 14, 2009 | 2001 Hyundai Santa Fe
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
Magnavox 15
IT IS YOUR POWER SOURCE HAD SAME PROBLEM CHANGED POWER PLUG HAS HOT TURNED OFF SINCE
Oct 10, 2007 | Philips Magnavox 15MF400T 15 in. LCD...
Boston Acoustics Recepter Clock Radio Logo
23 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
