Question about Video Cameras
Do you have
Hi I need the cd that comes with this camera as I have just bought one second hand. The disc I got with it does not play on my computer. Can you or do you have/get one? Phil Murfin 07786 236981 01474 321701 philmurfin64@btinternet.com
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Video Cameras Master
  • 102,366 Answers
What make and model is "this" camera?
Posted on Apr 24, 2013
Hi, don't know if I am sending this to the right bit or not. My son has an older version of the xbox and I bought him a second hand Lego Indiana Jones game which he loves, used to play ok then started...
this is in the wrong section... but... is there any visible scratches on the disc? if there is a visible scratch you can take it into a music store etc.. and they can polish out the scratch for less then $20 :) hope this is helpful
Feb 26, 2011 | Computers & Internet
Hi, bought a second hand wii for Christmas so don't know how old it is, bought FIFA 10 for youngest boy but it won't play on wii, a black screen comes up with a message to turn off power & refer to...
Try to play music cd's and other games to see if the Wii will read anything. Make sure the discs are clean as well. If the Wii is still not playing anything then that means the drive is bad and would need to be replaced.
Jan 01, 2010 | Nintendo Wii Console
Cd's won't play
Its dirty, try a disc cleaner, (brushes not solution) and if that does not work, its time to replace, (unless the radio is all ya want).
ALSO- if you are trying to play burnt discs, (cd-r, mp3 discs etc) than that could be the issue as not all indash cd players support non store bought cds
Aug 16, 2009 | JVC KD-S640 CD Player
Disc reading
How confident are you at opening it up? And where are you? If it can get table of contents info it could be gummed up grease on the laser sled.
Jun 15, 2008 | Denon CDR-M30 CD Recorder
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Help pleasee
I"LL SUGGEST U FIRST TRY TO FIX THE AUX INPUTS. CONFIRM WHETHER "AUX IN " IS "ON" or "OFF" .PRESS "SRC" SWITCH UNTIL "AUX 1" or "AUX 2" APPEARS ON DISPLAY. SELECT IT "ON".NOW HOPE FULLY THE CD PLAYER SHOULD PLAY.
May 03, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Why won't my cd player eject?
Hi Darla ,
If your problem is with new cd's your trying to play then the try this. New cd's often have around the inner and outter edges and if such disc is used, this may be the reason why it wont play. What you do is take a pencil and use the side of the pencil to rub the edges of the cd. It should clear it up. Now if your problem if that it wont let the cd come out the only thing i can think of is to press and hold the EJECT button and CD button at the same time for more than two seconds. Good Luck =)
Mar 03, 2008 | JVC KD-G120 CD Player
Phillips cdr 950 audio cd recorder
Hi Averil
Get yourself a copy of the manual directly from the Philips website (look on the left of the screen for all the relevant links)
Your CD recorder has a 2 pairs of phono (rca) sockets on the back.
Connect your keyboard's output (line out ideally or headphones if there isn't a line-out) to the inputs on the back of your CD recorder. And connect the outputs from the CD recorder to your amplifier. If you don't have an amp, you can plug headphones into the CD recorder so you can hear what you're playing.
Good luck! Let me know how you get on with it.
Jan 10, 2008 | Philips CDR785 3-Disc CD Recorder
Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
Video Cameras Logo
12 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
