Question about Utilitech 1/3-HP Cast-Iron 95 GPM Sewage Sump Pump 58117-UTL1
Pump won't shut-ff
I just installed the Sump pump, and it pumped out the intial tub of water. But the pump continued to pump and wouldn't shut-off
  • 7,482 Answers
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Posted on Apr 25, 2013
2 Suggested Answers
  • 512 Answers
SOURCE: I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Posted on Sep 16, 2012
Our auto irrigation system wouldn't turn off. We found the Davey XJ70 pressure pump was leaking so replaced the leaking pipe. Now the watering g system won't start. What do we do?
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
Mar 31, 2013 | Plumbing
When tub drains beeps twice and won't continue
Hi - Does the drain pump make a humming noise as well? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 23, 2012 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Washing machine does not empty
see the causes and use the common sense, God bless you.
Sep 19, 2012 | Ariston Technologies Washing Machines
I shut off my pump yesterday and water shot out of the skimmer. when i turned the pump on it wouldn't work, the pump basket has water in it but it isn't pumping anything, no water coming out of...
I suspect you had air trapped in the filter. When the pump shut down, the compressed air in the filter pushed back, turned the pump backwards, and unscrewed the impeller off the motor shaft. This particular pump doesn't use an impeller screw which prevents this from happening. You will have to pull the pump apart to see if this is the cause. I have seen this happen many times.
Sep 15, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
My front loader won't spin - the machine makes a noise when it is supposed to spin but nothing happens
sounds like a bad pump open the sumpm on the lower left side (preapre water to gush out if still in the tub) check if there is any objects in the pump or sump if yes remove and try if not replace the pump
Sep 02, 2011 | Asko W6021 Front Load Washer
I have a Zoeller Water Ridd'r II Model 48 Sump pump. The pump comes on okay, but will nit shutoff. The float is not impededd, it's just laying on the bottom of the sump. Is this a defective...
If I undrestand your description, when the resevoir is empty, the float lays on the bottom of the resevoir but, the pump doesn't shut off, after water is pumped out? You have to look at this as opposite of a toilet tank filling with water. In a toilet, the water rises and the foat turn the water flow off. In a sump the water will rise, and the float will turnthe pump on until the resevoir is empty, then it will open the system and turn off the pump. If the float doesn't rise, the resevoir will overflow and the pump won't come on at all. If the float rises and the pump comes on but, the float does "not" drop, the pump will continue to run after the resevoir is empty.
http://www.zoellerpumps.com/ProductByCategory.aspx?CategoryID=3
This is Zoellers link. I don't see your pump but they do have a support link. If the float rises and falls with the height of the water, turns pump on, then drops "all the way" and pump doesn't turn off, the switch is bad not the float. Make sure there is nothing in the way of the float dropping to it's full down position.
Jul 03, 2011 | Home
Water runs contiuously... tub never fills...cycle doesn't start.
Hi, You need to reset the drain hose. It needs to be over the water level in the machine. If you have it in a sump pump, it needs to be out of the water in the sump. If I can help you further, please let me know
Thanks
Vic
May 16, 2009 | Roper RTW4100SQ Top Load Washer
Utilitech 1/3-HP Cast-Iron 95 GPM Sewage Sump Pump 58117-UTL1 Logo
400 people viewed this question
Top Utilitech Plumbing Experts
Paul Carew
Dave
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
