Question about Fisher and Paykel GWL11 Top Load Washer
Fault code 5n1
I ahve just switched on the hot tub and it started OK but then stopped with the code 5n1. Is there a manual available to download?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
I'm assuming this is a Cal Spa? I'm going to reply to this but I'm willing to bet this issue resolved itself?
Error code of Sn1 ("Sensor 1"- Spa is shut down. High-limit sensor is not working.)
This could be a temporary condition. If not, your high limit sensor is bad. "SN" means your spa has a sensor error and "1" means it's the high limit sensor. Without knowing the year of your spa I don't know which manual to give you but the link below has just about every Cal Spa manual available.
http://www.calspas.com/manuals/
Posted on May 09, 2013
What does error 1 mean on my winer amc 2210 hot tub
Is this one of those Internet hot tubs?
An import from china?
don't know about the fault code, maybe check the owners manual?
As far as the spa, what is it doing or not doing, besides the fault code?
Apr 06, 2015 | Pool & Spa
KenmorenLaunry center not draining or advancing cycles
Hi David if the timer is not cycling the tub will not drain ,the washer will not complete cycles, second check the lock switch on the door. this can stop the timer and the tub from draining. when not cycling the timer is at fault , this could be two problems, 1st when everything stops check the door safety switch , 2nd listen for the timer, if it stops running. good luck ,geodaws
Dec 09, 2013 | Kenmore Washing Machines
Fault code on hot tub
Need more information on the tub. Do the circulation and therapeutic jets work?
May 18, 2013 | Washing Machines
Whirlpool WFW9250WROO starts a cycle and stops
Possible that the fault still relates to a program controller malfunction.
check the door switch , check the connectors to the board.
Jan 12, 2013 | Washing Machines
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Washer runs but the water does not turn off, THe waterm hot and cold just run until I cut it off manually.
while machine is filling turn of power if the water is still entering machine you have a mechanical fault water valve hot or cold needs replacing if water stops when power turned of you ave an electrical or control problem check water level hose from tub to level switch for damage or perishing if ok check water level switch blow into it see if it clicks if not replace also while blowing hold pressure to see if the diaphragm in the pressure switch is not perished keep me informed
Nov 05, 2009 | Washing Machines
Bosch SHU 6800 Water hot at sink only luke warm at the washer
BAD CONTROL BOARD TO TEST TO SEE IF THIS IS THE ISSUE RUN TEST PROGRAM
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by
pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ “20” = version 0 without jumper). When
wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and
REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display
alone). Cycle Countdown display will show "88" when REGULAR WASH button is pressed and "8h" when Delay Start
button is pressed.
To start testing, press both SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended,
Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added
together, (e.g./ “6” = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where
testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150ºF) and
water won’t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and
testing will end shortly after water has started circulating
Jul 18, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
Fisher and Paykel GWL11 Top Load Washer Logo
152 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
