Question about Canon Office Equipment & Supplies
Canon model h12425
Fax machine just started giving a loud beep when a fax fails. how can we turn the sound off?
  • 167 Answers
SOURCE: Fax machine beeping - Samsung SF5100
YOUR PROBLEM IS NOT VERY CLEAR,PLEASE TELL WHETHER--- A. DO YOU GET DIAL TONE ON THE MACHINE? B.WHEN THE MACHINE GETS INCOMING RING -IT IS SET TO ANSWER ON HOW MANY RINGS ? C. SWITCH OFF THE DRPD MODE. D,CLEAR THE MEMORY OF THE MACHINE TO FACTORY DEAFULT BY--SWITCHING ON THE MACHINE WHILE HOLDING THE STOP BUTTON AND THEN COOSING YOUR COUNTRY WHEN PROMPTED. SHOULD TAKE CARE OF THE PROBLEM... HAPPY FAXING OMNIPRESENT
Posted on Sep 25, 2007
  • 22 Answers
SOURCE: L170 Canon Fax Sound and volume control issues
Sunds as though you have the handset that came with the machine attached to it and the handset ring volume is still on. To turn that off there are 2 black inset switches on the handset itself turn those down or off.
Posted on Apr 22, 2008
SOURCE: Incoming Faxes won't print, states failed pickup and pages in memory
MACHINE WAS 3 NEW CALLS. WHAT DO I DO?
Posted on Jul 24, 2008
  • 272 Answers
SOURCE: MACHINE GIVE ERROR CODE 5100?
I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100. Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on May 30, 2009
  • 28 Answers
SOURCE: the ring is very loud when a fax comes in, volume control where?
This needs clarification. Is it the Handset on the machine that is ringing? If so there is a small slider control on the handset that can be adjusted down with a paper clip.But if the fax itself is to loud you'llneed to go inot programming and selct the Monitor Volume and set it lower or off.
Posted on Jul 11, 2009
Handset problem
hi there may be any key strucked on key pad
thanks
May 11, 2010 | Canon FAXPHONE L80 Laser
Canon H12425 that paper catches on when trying to fax
the gear inside the machine is bit moved you should adjust the gear to make it proper...
Apr 21, 2009 | Computers & Internet
The volume
There should be a volume button on the right hand, side of the machine
Aug 12, 2008 | Canon LaserCLASS Fax 710 Printer
We own a Cannon SuperG3, H12425 model, Serial #SPN42322 for our company FCN INC. We keep getting system error messages and the red alarm light is on. I have unplugged the back of the machine as well...
I had the same problem today, and what I did would I left it unpluged for about a 1/2 hour, then I plug it back in and it spit out a transmition report, and then the alarm light went off.
Try running a transmition report and see if that works for you.
Jul 29, 2008 | Canon Office Equipment & Supplies
Apr 09, 2008 | Canon FAXPHONE L170 Plain Paper Laser
LOUD SOUND WHEN SENDING FAX
There are 4 volume controls to access them press MENU.
You should see “MACHINE SETTING?” if not use the SET arrows to scroll through the different menus, stop when you see “MACHINE SETTING?” Now press the SET button.
Now use the up & down arrows to get to
Buzzer Volume = that the machine beeps
SET
Key volume = the tone that sounds when you press keys on the control pad
SET
Alarm volume = the alarm if something happens.
SET
Line volume = sets the level you hear at the fax is actively transferring a fax.
If you want to change any of the settings, press the up or down arrows to the level you like best and press SET if you don’t what to change that item just press SET. When you have adjusted all levels the way you want them press STOP and the levels will be remembered.
The most annoying sound to most people in the Line Volume. I have known people that like it as quiet as posable in thier work, but the problem is if you turn down the ALARM you won’t know when there is a problem. Many people like a little line volume so that they hear when they dial into a busy phone line, or if someone picks up the shared voice line.
Feb 12, 2008 | Canon L120 Fax Laser Printer
19 people viewed this question
old marine
old marine
