Question about Ignition System for Honda Civic GX NGV Sedan
Check engine light stays
Change the auto box and now the malfunction light stays on
  • 1 more comment
  • Rex Fling Apr 26, 2013
    I have been trying to find out rhat if it was plug in to a computer could it get re coded and would that solve the problem
  • Rex Fling May 17, 2013
    This has now been sorted By Pear Tree Garage Thanks
  • Honda Master
  • 15,639 Answers
What code comes up when you check the diagnostics?
Posted on May 06, 2013
Testimonial: "Have not yet had a computer put on it yet"
I reset engine management light and within minutes light comes on
If the check engine light or MIL - malfunction indicator light , or service engine soon light is on , it means there is a problem with the engine management system ! an it means it set a DTC - diagnostic trouble code in the PCM / ECM - electronic control module ! You can try resetting all you like but it's not going to stay out ! You need to have the vehicle scanned for codes an fix it ! Check Engine Code Scanner Advance Auto Parts
Feb 25, 2015 | Cars & Trucks
I change my transmission in 1997 honda civic freio I change the cvt to a manual transmission andengine check light stay on what could cause that to happen
Check engine lights report faults in engine AND gear box(auto). If you have changed from an auto to manual gear box then the sensor system for the gearbox is recording a massive fault with the gearbox that you have to check out. Talk wit an accredited auto electrician as to how to neutralise the system so that the light only checks out the engine.
Oct 10, 2014 | 1997 Honda Civic
2008 rhino 700 stays in low range even when shifter is in high revers light stays on and speedometer inop
Check the gear change lever where it joins onto the side of the engine/gear box. Could have slipped off or stripped the splined shaft. If that is fine and when you move the hi/lo range, and the shaft on the gearbox moves its possible the gear change mechanical levers have broken on the inside of the box.
Jan 14, 2014 | Yamaha 2008 Rhino 700 FI Auto 4x4 Sport...
2002 Voyager check eninge light stays on, lack of power, no auto gearshift
Go to autozone they will read the code in the car for free. Some other car parts stores might also read the code.
Dec 31, 2013 | 2002 Chrysler Voyager
I have a 2007 grand jeep cherokee. The malfunction indicator light is coming on after an oil change? Did the oil change have anything to do with it?
Probably not. The best place to start would be to visit Auto Zone or Advance Auto Parts and have them scan the computer and tell you what the check engine light means.
Jan 04, 2011 | Jeep Grand Cherokee Cars & Trucks
Check engine light stays on,but car runs perfectly. how do i reset engine light?
The light will only go off when the problem sensor or other malfunction is resolved. Auto zone or Advance auto parts will run a free diagnostic and tell you the problem. If the code is old they can remove it and all is well. You can also remove the negitive battery cable for 2 minutes to reset the code cache. hope this helps:)
Jul 01, 2010 | Hyundai Motor 2002 Elantra
Why would my check engine light stay on
The engine computer has detected a malfunction in the system. You can take the car to you local auto parts store (national chain), and they will read the code from the computer for free. Afterward, they can sell you a replacement part and turn off the light.
May 15, 2010 | 1990 Nissan Stanza
Engine Light on Dashboard stays ON while driving
The check engine light can be anything, in order to help you further you need to get the codes out of the computer. to do this you need to either A. Buy a cheap code reader from an auto parts store, B. Go to an auto parts store like Advance, or Autozone or pep boys, and they Usually will read the codes for you for free. Then you need to post back here with the code read, and We can help further
Apr 07, 2010 | 2005 Dodge Grand Caravan
VSC and Malfunction Indicator came on and stays on
When you say malfunction indicator , do you mean `check engine`` light.
These paired lights can indicate a change in engine air flow and fuel mixture. Try a fresh tank of premium fuel, but first a unscrew and re-screw the gas cap until it ratchets into place. The lights can be triggered by a loose gas cap, a fouled O2 sensor, and several other emission related problems including sticking throttle body components, etc.
This can sometimes be sprayed with carb cleaner inserted in the snorkle area of the air intake where teh snorkle meets the metal intake.
Dec 07, 2009 | 2008 Lexus Rx 350
2004 gmc yukon gas peddle doesnt work
No,It is called limp mode,It is so that when the vehicle has a major mechanical problem,It can still be driven to the shop.
May 11, 2009 | 2004 GMC Yukon
Ignition System for Honda Civic GX NGV Sedan Logo
64 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Mike Carew
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
