Glass screen is breaking away from body of tv
The set is a new Samsung LN52A750R1F. The glass screen is coming loose from the main body at the corners, as if curling. The set was wall mounted fresh out of the box over a fireplace mantle. Three out of the four corners appear to ''snap'' back when pressed, the lower left corner appears to be getting bigger and will not snap back. The entire glass screen seems to becoming looser. The set has never been moved except when it was installed.
    President:
  • 1,779 Answers
Please return it ASAP. This is not normal.
Posted on Mar 13, 2009
My top glass on my samsung galaxy s 2 has cracked trying to take it off to put new glass on but its glued on have you any tips how get the glass off it stuck on good
it's not recommended to try to replace the glass only because of the reason you've encountered because you could well end up breaking the amoled screen in the process.
It's far easier to replace the glass and screen together as one unit.
Nov 01, 2013 | Samsung Televison & Video
I see red dots on screen of dlp samsung tv. Not sure why. Could be a bad lamp? When I watch tv thru regular tv cable between cable box and tv , the tv is loosing signal.Thru s video signal is ok.
optic block failure is the dotty appearance use your model number to shop around for a new one and the coaxial input's are easy to break loose so use s-video if at all possibly ok
Dec 31, 2010 | Samsung DLP HL-P5663W 56" TV
Picture on Samsung lcd LNT5271F is blurred sometimes lines color distortion double images then goes away and will come back. Part of the screen will go completely lines then come back. Starting to happen...
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
May 12, 2010 | Samsung LN-T5271F 52 in. LCD Television
Was watching my vizio and i heard a pop and the screen went blank, but there still is sound, its about 4 years old can it be fixed and ballpark on how much it would cost to fix!
Main Power Supply issue! The repair would cost you more than what a new flat panel would cost you. Vizio is a Chinese made TV. Only lasting 3.5 to 4 years. Go out and buy yourself a new Christmas gift a new flat screen TV. Try to get a name brand one like Sony, Samsung or Panasonic. They have great service records. Vizio is your typical breaks, throw it away.
Blessings always,
A/V Media Tech Guy
Nov 28, 2009 | Televison & Video
Cracked LC37D62U LCD TV
It is broken,The outside is a Polorised film.Like window tint,It is repairable,New LCD screen.But may be cheeper to buy a new TV. GET A EXT.WARENTY!!! will not cover accidents but the new tv's do break alot,and are expensive to repair.
Buy a name brand, NOT RCA "junk" Just a name
no longer a company. Samsung,Panasonic,Sony. If you want to support the USA buy another Sharp. Still a great TV. And made in America. NOTE they make after market screen protectors. GOT KIDS? GET ONE. :) Or even a piece of plexie glass if cash is tight. Hope this helps.
Oct 25, 2009 | Sharp LC-37D4U 37 in. LCD Television
Sony Trinitron KV35V36 Glass Chip
your best bet if you dont have a warranty on the tv is to get it repaired shouldnt be more then 150.00 you dont want the risk of having to fix something else if you get into the tv.
Nov 30, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Broken Screen on Plasma TV
samsung 37 inch plasma screen cracked by my grandson. Can it be fixed
Jan 13, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
TV Black-out
a tap on the side tells me that it's a solder connection broken loose, most likely in the horizontal section. if you have experience with electronic soldering, you can fix it, otherwise take it to somebody that can fix it. thermal expansion and contraction(from turning the set on and off) eventually produces metal fatigue in solder connections, and the connection breaks loose, just enough that it sometimes works, and sometimes doesn't.
Jun 28, 2006 | Sony KV-27S20 27" TV
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
