Question about Vehicle Parts & Accessories
Reset check engine light
Check Engine reset on 2009 Cadillac Escalade
  • Vehicle Part... Master
  • 17,328 Answers
You need to have an OBD 2 scanner. If the code wont reset, the problem is not gone.; You can go to autozone to see the code and have them reset it for free.
Posted on May 09, 2013
How to reset check engine light on a Cadilac Escalade 2005
theres no reset button you need to get code checked and fix problem
Feb 23, 2015 | 2005 Cadillac Escalade
Can autozone pull the fault code for a 2009 Cadillac Escalade Service Airbag light
No, the scan tool that autozone uses will only get to the engine trouble codes. It will not access the airbag or antilock brake, or transmission codes.
Aug 26, 2014 | 2009 Cadillac Escalade
Check engine light is on, tester says low fuel pressure
have a fuel system pressure test done to check pump--regulator and filter. IF everything checks out replace the pressure sensor. Reset the light with a code reader
Feb 01, 2014 | 2005 Cadillac Escalade
My 2003 esv escalade reduced power engine reading always shown. When press the gas the engine idle. I stop the car some minutes and the it works but the yellow engine symbol at right stays yellow bothering...
You need to have an OBII scan for faults. Any good shop or parts store can scan it for you give you list of faults/fixes. Once repaired then they can/will reset lights
Feb 22, 2011 | 2003 Cadillac Escalade Esv
How do you reset the check engine light
CHECK ENGINE is one warning about any fault code stored in the PCM; disconnected the battery few minutes to reset it, if the light turn on again, then scanned the PCM to know exactly what code in there.
Keep in touch.
Sep 14, 2010 | 2004 Cadillac Escalade
The car runs fine but check engine light came on. 2003 Escalade
You have to take it to a mechanic to read the fault code. Some auto parts stores can read and reset domestic (American) vehicles
Dec 15, 2009 | 2003 Cadillac Escalade
There is a
Before you try that try your gas cap, you can have it tested at most auto parts stores. First check to see if it is on tight if not that can cause that exact failure.
Before doing anything you should find out what engine code is causing the light to come on, I know autozone will check that for you and reset the code for free. Try that first , this will allow you to target the problem rather than hunt for it.
Dec 02, 2009 | 2005 Cadillac Escalade Esv
I have a 2005 Cadillac Escalade EXT and the check engine light came on. when checked the code 930 came up. What dose this mean?
i guess you mean p0930 obdii code... that is gear shift lock selenoid circuit problem....when press on brake does gear shifter move freely.. anyway reset and see if returns... if problem with gear shift try replacing selenoid
Sep 04, 2009 | 2005 Cadillac Escalade Ext
Resetting service engine soon light in my 2002 cadillac escalade
  1. Turn the ignition key to the RUN position.
  2. Press the INFO button on the Driver Information Center (DIC) button to display ENGINE OIL LIFE.
  3. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the he procedure if the system does not reset.
  4. Turn the ignition OFF.
Feb 01, 2009 | 2002 Cadillac Escalade
How do I reset "service engine soon" indicator light?
Either take it to a dealership and have the mechanic do it for you,,or purchase a code reader for your vehicle of ebay and do it for yourself.
Jan 19, 2009 | 2002 Cadillac Escalade
Vehicle Parts & Accessories Logo
89 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
