Question about REXON Nav / Com Aviation Transceiver RHP-520
Looking for a new battery
Need a new battery pack and charger ni-cd model nbb-487 12 v
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
Dewalt 30 Minute Fast Charger does it work in uk 230v
Some battery can not be charged by fast charger, because this can damage the battery. You can think to replace it to a new charger, a 7.2V 9.6V 12V 14.4V 18V NI-CD NI-MH BATTERY charger for Dewalt
Jun 22, 2014 | Drills
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Feb 15, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Do you know where I could find a user guide manual for a NEXXTECH Ni-Cd/Ni-MH 2300033 battery charger?
Radio Shack 230-0033 appears to be the same charger.
I have this charger (Nexxtech branded, model 2300033) and the specs all appear to line up. However, I don't have the manual.
http://support.radioshack.com/support_electronics/71094.htm
Aug 23, 2012 | Cameras
I have a makita 6391D cordless drill with 18v ni-cd 1.3ah batteries, just had one battery and charger stolen so have to buy replacements is there any way i can convert it now to lithium batteries if
I can't find a Makita model 6391D drill but they do have a model 6390D drill that takes the 18V Ni-Cd pod battery. The tools and radio don't care what type of battery you use, only that they are 18V. However, to date, Makita does not make a Li-Ion, pod battery. All of their Li-Ion batteries are the slide-on type. Your options for that 18V tool is the 2.6ah Ni-MH battery (PN 193159-1 for a single or 194158-6 for a twin pack), the 2.0ah (PN 192827-3) and 1.3ah (PN 194107-3) Ni-Cd batteries.
Jul 06, 2012 | Drills
How long should a fully charge battery last on WG250E Hedge Trimmer
This is the info i found on WG250 battery . It says up to 50 min below in the features. Hope it helps
Battery
The WORX WG250 hedge trimmer incorporates an 18-volt 1.7 Ah Ni-Cd battery pack. You can use this battery pack with other WORX Ni-CD PowerShare tools. The included charger takes about an hour to restore a dead battery to full charge.
Cordless Hedge Trimmer 18v Worx WG250E jQuery(document).ready(function($) { $("a[rel=product-image-gallery]").fancybox( { 'transitionIn' : 'elastic', 'transitionOut' : 'elastic', 'titlePosition' : 'over', 'titleFormat' : function(title, currentArray, currentIndex, currentOpts) { return 'Image ' + (currentIndex + 1) + ' / ' + currentArray.length + ' ' + title + ''; } }); });
Features
  • Wall mount bracket
  • 3 position adjustable front handle
  • overmould soft grip for user comfort
  • Quick release handle
  • Double insulated
  • Volts: 18
  • Blade length: 510mm
  • Cutting capacity: 14mm
  • Blade action: Dual
  • Run time: Up to 50mins per charge
  • Charge time: Up to 1 hour
  • Machine weight: 3.1Kg
  • Comes with one battery and a charger
Sep 13, 2011 | Worx Wg250 20inch 18volt Cordless Hedge...
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
SPECYFIKACJA :
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
I lost the battery charger for the BigFoot toy. Can I buy one?
I know you can get these on Ebay. Also most NI-MH 9 volt battery charges will charge this battery pack. You can use a 9 Volt Snap Battery Connector with Alligator Clips to bridge the connection between the battery pack and the NI-MH 9 volt batter charger. This is how I charge this battery pack now. You can probably get the 9 Volt Snap Battery Connector with Alligator Clips at a radio shack or on Amazon... as well as a NI-MH 9 volt battery charger.. don't hook up the leads backwards :)
Aug 10, 2011 | Mattel Fisher-Price Imaginext Big Foot
REXON Nav / Com Aviation Transceiver RHP-520 Logo
Top REXON Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a REXON Audio Player and Recorder Expert? Answer questions, earn points and help others
