Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
How to replace brass bar for torsion spning on toro 20066 mower?
How do I get brass bar back into handle after replacing spring?
2 Suggested Answers
  • 89 Answers
SOURCE: what locks in the left and right torsion springs
the proper set up on thre bar which hols thr springs is plate lock handle part 107-3946 then the right hand torsion spring 108-0953,make sure the spring hooks over the plate lock, then left hand torsion spring then bar slides through left hand hole and lever release 40-1823-03 attaches to end of bar with a set screw
Posted on Nov 04, 2009
How replace tortion spring on toro 22 per pace l/mower
put the deck on the ground
push the deck lever fully forward
use a pair of vice grips done up tight and pull the end of the spring into the hole
Aug 29, 2015 | Toro Garden
Torsion Bars
No, your Honda does not have "torsion bars". You have a coil springs to absorb bumps and give the suspension compliance. A torsion bar was used on many Chrysler products and older vehicles. You may be confusing "torsion" bars with "sway" bars. A sway bar links suspension from side to side to keep the vehicle "flatter" in corners as an aid to handling.
Aug 24, 2013 | 1997 Honda Accord
How do I replace the torsion spring in the handle of a Toro Personal Pace lawnmower?
Thanks so much Jamie. I had the top of the handle off but couldn't get any
further. I had to use a screwdriver on one side to get the brass bar out of the
plastic channel (I was afraid I would crack the plastic but didn't). I was able to remove the bar from the handle by myself with lots of effort ( BTW in your
solution did you mean your son pulled vertically up on the handle while you pushed vertically down on the bar?). I had one foot on one side of the handle and pulled up on the other side while pushing down on the bar. Isn't the web and Google amazing. The Toro sight didn't have a service manual. So I just typed "How to replace the torsion spring on a toro lawnmower" in Google an the question came up. I think Toro has a design issue with an overstress point on the spring. That part is on back order at the factory.
I did it.
May 01, 2012 | Toro Personal Pace CARB Walk Power Mower
I have a 1988 Model 26624, 21" Key-Lectric mower. I've noticed over a period of time that the mower blade slows considerably when cutting the lawn. At first, I thought it may be grass accumulation under...
Yes, it sounds like you need to adjust the blade brake clutch (BBC). I have a PDF service manual that explains it. If you post your email address I can upload it to you. Here's an excerpt from the manual:
BBC
BBC Adjusting the Blade Brake
1. Stop the engine. Pull the wire off the spark plug.
2. Remove the two screws securing the screen
panel to the top of the mower housing as shown
in Figure 22. Remove the panel. (The panel they're
referring to is the red screen between the motor
and handle.)
3. Move the control bar down and lift up against the
handle. With the control bar against the handle,
measure the spring length (L) at the front of the
spring as shown in Figure 26.
4. If the spring dimension is greater than 32 mm
(1-1/4") an adjustment is needed.
5. To adjust, loosen the bottom jam nut on the blade
brake cable as shown in Figure 27. Adjust the top
jam nut until spring dimension is as near as
possible to nut; not less than 25 mm (1") See
note below.
NOTE: Adjusting the top jam nut too high can
cause the cable end to crush the plastic fitting
when the control bar is moved up against the
handle. If the spring cannot be adjusted to less
than 32 mm (1-1/4") before the cable end
contacts the plastic fitting, the clutch belt is worn
out and should be replaced. After replacing the
belt, adjust the cable per the above procedure.
NOTE: 1990 and newer models are equipped
with finger tip adjusters that do not require tools.
Use the same adjustment criteria on these
cables.
Sep 18, 2010 | Toro Lawn Mower With Toro Power Tools
Toro self propelled model 20066 loud noise once engaged
They will honor it - go now - - quickly and simply explain things - Toro is a good stand up company.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
What locks in the left and right torsion springs
Sep 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Self Propel Cord Replacement too loose!
measure it from the old cord thats the easiest way ?
Aug 26, 2009 | Toro Lawn Mower With Toro Power Tools
When I hold the bar down that engages the blade my hands hurt .
There is a possibility that the spring one of the ends of the cable attached to the bar you are holding has stretched causing you to have to grip it harder to make the mower work. First try taking the end loose from the bar and tying a knot in it to make it a bit shorter. This usually works, but you may have to replace the cable.
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
Rear torsion bar
the car has rear springs for sure. there is no adjustment you have to replace the springs.
Jan 13, 2009 | 2000 Ford Taurus
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
