Question about Mission Audio Players & Recorders
Speaker vibration speaker vibrates when you turn the volum up
  • nicholas montanari Apr 26, 2013
    i have a mission 700s speaker when you turn the base up it vibrates
    what can i do to stop this from happening thanks
  • Mission Master
  • 17,328 Answers
Check for loose or broken parts. .Check speaker cone for damage and check voice coil for burnt wires with an ohm meter
Posted on May 13, 2013
I have the Klipsch Sub-10 Subwoofer, and it no longer plays music. Now it hums (vibrates constant) and corresponds (louder or softer) with volume control. Light is home but no one home situation. V
Does the subwoofer have the same hum when the input cables have been unplugged? Many input cables use very fine conductors, which often fail. A bad cable will often introduce a hum and prevent a signal from getting through. If the noise is still present without the input cable(s) connected, then repair options are limited. No schematics are available. There's a daughterboard that has been available, but its failure usually causes the system to die (short-circuit). The cost to repair the amplifier may be close to the cost to replace the entire sub.
Sep 14, 2014 | Klipsch Synergy Sub-10 Subwoofer Speaker
Why are my headphones making a vibrating sound on the left side, when there is a lot of bass.
Each speaker works independently from each other. One speaker may use more low frequency tones than the other one.. Low frequency tones create a lot more noticeable vibration than higher frequency tones. You can reduce it by turning the volume down a little on the left speaker. It is possible that nuts came loose on the speaker.
Jun 01, 2014 | Beyerdynamic DT 770 PRO Professional...
My television has static and a vibration when the volume is increased to about 20 and above
don't increase abouve 20 again because it can spoil the speaker vibrating
Sep 27, 2011 | Philips Televison & Video
If the speakers vibrate especially when the mega bass is on, does that mean that the speakers are blown on my icf-cdk50?
Real low bass is mostly vibration. Anything that has a "mega bass" 'enancement' is cutting corners to make up for bass-reproduction shortcomings. Speakers measuring 2-5/8' have no business reproducing real bass. Blown speakers would be silent. Torn cones from excessive volume might sound like unwanted vibration. Your vibration might be a resonance of the unit's own housing, mounting hardware or something nearby. Try moving it to another location.
These units are not economically repairable. If you like it and you think it's broken you might snag a whole new on on eBay with wise bidding.
May 10, 2011 | Sony ICF-CDK50 Under Counter CD...
Why does my lg tv vibrate as i turn the volume up? to hear the tv it gets turned up to 40 and above on the volume control, it just vibrates when it's that high. there's no vibration at 20 or under, but you...
This is a inherent problem in the LG 7 series LCD. It is because of poor padding in between the speaker and the bezel along with a very thing back that causes the TV to vibrate at certain frequencies and volumes. LG is aware of this issue and has new speaker brackets and spaces that will fix the issue. You can contact them and explain your situation if they can send a service center out to fix the issue under warranty as it is less than a year old. If you cannot get it covered, it should still be a cheap repair as the parts should only cost around $20 and take less than one hour of labor for a technician familiar with the issue.
Oct 08, 2009 | LG 37LC7D 37 in. LCD HDTV
I cant put my text mesg on vibrate
Navigate to Settings > Sounds > Volume > Messages > Text Message. Vibrate on needs to be checked. Lower the ringer volume by clicking the left arrow.
Apr 09, 2009 | LG Lotus Cell Phone
LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Rattle/Vibration in sound quality - Hitachi TV
Replace the main board and it should correct this, if it did it all the time I'd say its a bad speaker but since it works ok to start with sounds like a bad audio output chip in the main
Dec 02, 2017 | Hitachi Televison & Video
Top Mission Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mission Audio Player and Recorder Expert? Answer questions, earn points and help others
