Question about Maytag 24 in. PDC3600A Built-in Dishwasher
Sears dishwasher soap dispenser door wont open-loose spring
Sears Model 665 15719000 dishwasher:
this dishwasher maybe 4 years old. The sping that holds the soap door open is loose and doenst want to open. can this be easily repaired??
    Genius:
  • 1,066 Answers
With new parts ...yes.
Posted on Mar 13, 2009
Detergent door wont close
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 09, 2011 | Hotpoint 18 in. DC26P Free-standing...
Soap dispenser wont open to release detergent?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Oct 26, 2010 | KitchenAid 24 in. KUDS02SRSS Stainless...
The soap dispenser won't open during the cycle on my 15782 model Kenmore Dishwasher. I am using gel pack soap...so I do not have old soap caked in the receptical. Any thoughts?
Hi
Daniel
Oct 26, 2010 | Kenmore 24 in. 15782 / 15784 / 15789...
Soap dispenser lid doesn't open
Hi
Oct 25, 2010 | Whirlpool Dishwashers
Soap dispenser will not open
Hi
Oct 20, 2010 | Jenn-Air Dishwashers
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
1h (?) signal, and soap dispenser doesn't open
The part called a Wax Motor (about 2 inches) inside the door is responsible for opening your dispenser.Check it / replace it.
Oct 09, 2007 | GE 24 in. Profile PDW7800 Built-in...
Maytage dishwasher soap dispenser not operating properly
I have an older (1990) Maytag dishwasher that had the same problem. In my case liquid dish soap had penetrated the seal and dried out causing the rotating cover shaft to freeze up.
Remove the door panel and then disconnect and remove the soap dispenser from the door. Make a diagram of the soap dispenser as you carefully disassemble it; there is a coil spring around the soap door axis. If you find a buildup on the door shaft or in the hole it rotates in or in the groove the door rides in, try removing the residue with a plastic scuffy pad after letting it soak in a lime scale remover (Lime Away) or some other cleaner. I think Jet Dry makes a dishwasher cleaner. Before you reassemble the dispenser, wipe a thin film of plumbers grease (available at Home Depot or Lowes) on the shaft.
If the door is free turning and doesn't appear to be bound up, then the problem may be with a heating element that expands when energized, allowing the door to open to the second soap compartment. An ohmmeter will be needed to test the thermal lock.
These jobs are fairly simple and should need only a Phillips screwdriver and a volt ohmmeter.
Happy Motoring!
Mar 06, 2007 | Maytag 24 in. PDB1420 Built-in Dishwasher
Maytag 24 in. PDC3600A Built-in Dishwasher Logo
290 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
