Question about Music
Aria serial number lw5t - Music
Aria model A543F serial number is 00173 How Old is this Guitar ?
Information on Aria serial numbers is scarce, but what there is indicates the guitar was made in the 17th week of 2000.
Aug 24, 2017 | Aria Music
I am interested to know what year has been made it Aria Matsumko serial number H800030 its has been made it in japan.
is your question is about the Aria Matsumoko guitar here is a link where you can find that information about the year that it was made. http://www.matsumoku.org/models/serial_no.html
Jan 13, 2017 | Aria Music
What year is an aria with a serial number 078036
Only a small number of Aria guitars had a serial number which gave the year of manufacture unfortunately. I can find no date for this one, sorry.
Nov 06, 2016 | Aria Music
I have a M. Schulz Co. piano from Chicago. It has the date that M. Schulz was establish 1869 inside, along with the serial number 76271. Any idea how old it may be?
Good thinking :>) Also remove the middle C key complete and see if there is writing on it.
M. SCHULZ & CO.
Pianos, player-pianos. Grand and Reproducing Pianos known throughout the piano world as instruments of the highest class. The M. Schultz piano of the best known, most highly organized, reputable and extensive piano manufacturing concerns in the country. Technically, the instruments made by this concern and note for scientific correctness of scale, highest grade of workmanship, and extreme care in choice of only the finest in material, backed up by long experience. The tone quality of M. Schulz pianos is the strong point of them, possessing a roundness, purity and mellow singing beauty all its own. This company is also distinguished for turning out case work of true artistic excellence, with a purity of design and fineness of finish which are in every way distinguished. Added refinements in case designs of special period art models are features of M. Schulz Co. production. Aria Divina Reproducing pianos are a standard with dealers everywhere.
1907 - 3500 1913 - 80000 1919 - 140000 1925 - 190000
1911 - 62000 1917 - 120000 1923 - 170000 1929 - 226000
1912 - 71000 1918 - 130000 1924 - 180000 1930 - 230000
Feb 18, 2016 | Music
Is the serial number J96107 a real serial number? I was told that they only went up to J96096.
As with any hardware, you need to supply a "brand name" or manufacturer and what the "model number" is. Of course, a model number is not a serial number. Even within a brand, each model may have its own set of serial numbers. I suggest you do a google search for "brand serial numbers" replacing the word brand with your specific brand. But here is a short cut that may serve you well:
http://musictrader.com/?page_id=61
If you want to try another type of direct google search for your:
If you do not know the brand, then try the type of instrument and serial numbers. That may offer you a list of different instrument brands with links to serial numbers associated with them. Here is a result for a search for clarinet serial numbers.
For example: http://www.woodwind.org/clarinet/Equipment/HowOld/
Aug 26, 2015 | Music
Aria guitar serial number 65107005
I can't say about the age, but they seem to be in production still. CGp indicates a classical guitar, rather than an 'acoustic' guitar. the difference is in the strings. Classical guitar strings do not have the tension od regular steel acoustic strings. The fingerboard is usually flat and wider. I don't think they made these back in 1965. The serial number is different for each manufacturer and you would have to ask the manufacturer.
Jun 05, 2014 | Music
Aria serial number i'm looking for a site to be able to find out the exact model of bass guitar from a manufactueres serial number
that solution may be a little tough.go to manufacture first to see whats up if none go back and find diiferent people that deal with guitars and ask around about the brand and see if you can be pointed in right direction
Jun 19, 2013 | Aria SB CB Bass Guitar
Hi, might as well give this a go. My Aria IGB35 (4-string) dosent work electrically. Thats all the info I'm able to give and dont wanna pay some guy 35 quid to fix something I could do myself. Any idea...
OK, plug in a cable, borrow a multimeter from a friend and meaure the output resistance on the other end of the cable, between the 2 connections on the plug. Should be between about 3000 to 15000 ohms with volume control flat out. Then report back here with your findings.
Apr 25, 2011 | Aria IGB 35 Bass Guitar
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
