Question about Jet Health & Beauty
How to replace replace wheel bearings - Jet Health & Beauty
    Sergeant:
  • 317 Answers
Make, model??? Since I don't know the model: wheels normally slide onto the gearbox shaft key and is held in place with a nut and washer at the end of the shaft, The bearings are located on the drive shaft, inside the gearbox housing, next to the wheel assembly. They are usually pressed on and requires disassembly to press them off and replaced.
Posted on Jun 06, 2013
How do you replace the rear wheel hub on a 2003 Kia sedona. All I can find is directions on front not back.
Wheel Bearings
Print
Adjustment
2002-05 Models
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    Rear wheel Brake drum Hub cover Cotter pin Lock nut cover
  3. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm).
Removal & Installation
2002-05 Models
    Rear wheel Brake drum Hub cap Cotter pin Lock nut cover Lock nut Wheel bearing retainer washer and the outer wheel bearing Hub assembly Grease seal Inner wheel bearing
  3. Clean and inspect the wheel bearings and races for unusual wear or damage. Replace parts as necessary.
To install:
  1. Pack the wheel bearings with grease for assembly.
  2. Install or connect the following:
    Inner wheel bearing Grease seal Hub assembly Lock nut. Adjust the locknut to achieve wheel bearing play of 0.001-0.006 inches (0.025-0.152 mm). Lock nut cover Cotter pin Hub cap Brake drum Rear wheel
Apr 03, 2015 | 2003 Kia Sedona
Procerure to replace wheel bearing assy 2004 nissan altima 4cyl
Go to YOU TUBE and put in replacing wheel bearing hubs for
nissan altima & watch
There is a lot to see even if on a different vehicle
I doubt you have the tools to do the job
Sep 19, 2012 | Nissan Altima Cars & Trucks
Wheel bearings replace
Loosen axle nut.Remove tire & wheel.Remove bolts from strut.Disconnect outer tie-rod end.Remove brake caliper.Disconnect wheel speed sensor connector.Carefully push axle shaft out of the wheel bearing. Be carefuly not to over bend the CV joints.Note: depending on the mileage, I often replace the half-axle at this time as well.Remove three bolts holding wheel bearing in place.Remove and replace wheel bearing.
Jan 01, 2012 | Oldsmobile Cars & Trucks
How to replace the front wheel bearing on a Hyundai Accent 2000?
Wheel bearing for all car makes available here. You can replace your wheel bearing here. http://www.buyautoparts.com/part/replacement-wheel-bearing/
Apr 02, 2011 | 2000 Hyundai Accent
2wd front wheel need to replace bearings or hub assembly which is best
A Front Wheel Drive Vehicle Can Have Two Types Of Rear Wheel Bearings: Serviceable Bearings, Or Nonserviceable, Sealed Bearings. When Sealed Bearings Fail, The Bolts Holding The Bearing And Hub To The Axel Or Control Arm Must Be Removed. When Installing The New Bearing Assembly, Torque The Bolts To Specifications.Some Manufacturers require The Use Of New Fasteners When Rear Bearings And Hubs Are Replaced.
When A Serviceable Wheel Bearing Is Used, The Bearing Can Be Disassembled And Packed With Grease.It Is Serviced Like A Front Wheel Bearing On A Rear-wheel-Drive-Car.
Apr 09, 2010 | 2003 Ford Explorer Sport Trac
I get a vibration as im driving possible from the rear wheel
a) Wheel Balance.
b) Wheel Alignment
c) Wheel Bearing.
My best guess is a wheel bearing needing replacement. If there is only noise, then MAYBE repacking of bearings. However with vibrations, the wheel bearing(s) need to be replaced. Make sure you replace both the bearing and races as a set.
Let me know if this helped or if you need additional help.
Dec 09, 2009 | 1992 Plymouth Acclaim
How to change a rear wheel bearing on a 1994 toyota camry
The rear wheel bearing on a toyota camry is replaced by replacing the wheel bearing and hub as a unit. this is a design change as compare to older models with two piece wheel bearings. Scotch drive wheels. Remove rear wheel. Remove rear brake drum. (note: if emergency brakes are applied you will not be able to remove brake drum) Remove dust cap and hub retaining nut. Hub should slide off as unit. Replace hub with new unit. Installation is reverse of removal.
May 30, 2009 | 1994 Toyota Camry
Wheel bearing replacement left front wheel Hello Everyone, I may need to replace the wheel bearing on my right front wheel of my Corolla wagon. How can I know for sure? And how can I find out how to do...
Diagnosing the bearings can be tricky depending on severity of wear. Typically - drone noise at highway speeds, squeeling, clicking or grinding noises at low speeds that reduce during braking, or pull off the wheel and brake assembly and check the bearing for slack or smoothness of rotation by hand. While doing this, check the brake assembly thoroughly - generally a more likely culprit of wheel noise.
Wheel bearing replacement is not for the novice backyard mech. - you will need pullers, press, etc. If you can get a rebuilt assembly - much easier.
Apr 23, 2009 | 1996 Toyota Corolla
Health & Beauty Logo
37 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
