Sony KP-51WS500 51 in. Rear Projection Television
Problem for Sony KP-51WS500 51 in. Rear Projection Television
Sony TV rear proj works but color is blue
By twinhipper on Mar 13, 2009
TV works, all the channels come in clear but in blue color. Sony Model KP-57WS500.
How do I get the color back?
Comments:
Mar 14, 2009
- No lines, just a blue hue picture. TV stays on and does not shut off by itself.
Apr 07, 2009
- It took me a week to look at the set. I followed these instructions:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
Unfortunately, the screen remained blue... so off to the trash.
Thanks for all the input.
Clarification Request
Posted by Joe1974 on Mar 14, 2009
Is it possible to post pictures of this problem? It would help tremendously.
Posted by Joe1974 on Mar 13, 2009
With this problem, are there lines in the picture around an inch or 2 apart kinda going diagonal across the screen? Does the TV ever shut itself off?
Same Problem
Mar 15, 2009
-   THE PICTURE COMES IN FOR A TOTAL OF 10 SECONDS THEN THE SCREEN TURNS BLUE...THEN TURNS OFF.....THE POWER BUTTON FLASHES 8 TIMES-   christyk6
Solution #1
posted on Apr 02, 2009
Somewhat Helpful)
arjuun
Rank: Guru
Rating: 86%, 434 votes
Problem : Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution :
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Was this helpful?
Yes
No
Solution #2
Not Rated)
christyk6
Rank: Apprentice
Rating: 0%, 0 votes
I fixed my > KP-51WS500 51 in. Rear Projection Television myself...I took the front off and turned the middle bottom ("bolt?)marked with a B and walla....I turned it the tiniest bit!!!! Just like new!!!
Was this helpful?
Yes
No
Popular Solutions for Sony KP-51WS500 51 in. Rear
Questions and Unsolved Problems for Sony KP-51WS500 51 in. Rear
Do you recommend Sony KP-51WS500 51 in. Rear Projection Television?
Answer
Answer
filter cleaning , picture is getting shadey light only in the center of picture
Answer
does anybody know where i can get a blue crt bulb for this tv.
Answer
can I separate a Sony kp51ws500 projection screen from it's base where the speakers are located? I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
