Question about Android Apps
Bluetooth I change new battery then also IR Blaster( bluetooth is not connecting to samsung tv 7500)
Reboot and try to make your phone visible
Posted on May 03, 2013
Bluetooth connection
I've never seen a TV with built in Bluetooth. Some sound bars can connect to your phone with Bluetooth and others use Bluetooth to enable the accompanying subwoofer to operate wirelessly so you can place it anywhere. Most sound bars connect with an optical cable to audio out or digital out on the back of the TV.
Nov 27, 2015 | Samsung Televison & Video
Battery Backup of my WEP 200 Bluetooth Headset
I purchased new Samsung WEP 200 Bluetooth Headset but its Battery Backup is not even 1 minute. From where I can get the battery. I am based in Vijayawada, (A.P) (India) & what could be the approximate cost.
Oct 29, 2009 | Samsung Bluetooth?® WEP200 Headset...
I got a new bluetooth for my Samsung Black Jack ll. How do I get the old bluetooth off my phone so it will accept the new bluetooth?
Start > Settings > Connections > Bluetooth > Bluetooth
Highlight your Bluetooth device
Open Menu and select Delete
If this helps please vote for my answer.
Sep 13, 2009 | Samsung BlackJack II Smartphone
Cannot install java on samsung i640
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
BUT THERE ARE SOME UNOFFICIAL METHOD PLEASE TRY THIS BUT RISK IS WITH U.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Jun 26, 2009 | Samsung SGH-i640 Cellular Phone
Samsung TV remote control controls two Samsung TV in same room.
You cannot reprogram the samsung remotes. I just installed three samsung tv's on the same wall. I used a harmony 900 remote. It has a rf receiver with an IR blaster two IR emitters. You can designate each emitter to a specific device in the remote. I used the main remote IR for the main tv, The blaster for the a/v receiver,blue ray, ect. Then I used each of the emitters for a tv. I can control each of the tv's independently with no interference.
Mar 07, 2009 | Televison & Video
Bluetooth headset
In the Connectivity menu, you can change your phone connectivity settings. You can turn Bluetooth™ and IR on or off, change the default mode for your phone when connected via USB hope this wrks..All the best
Happy to help
Have a nice day!
tc
May 30, 2008 | Sony Ericsson W850i Cellular Phone
Activesync via bluetooth
Click on Ipaq wireless
turn on the blutooth
Click on Manager
at the bottom click on new
and then click active sync via bluetooth and go from there
Jan 02, 2008 | HP iPAQ HX2490 Pocket PC
Bluetooth handsfree connectivity
Bluetooth handsfree profiles are needed by N 72 which is missing by default in N 72 you will have to install bluetooth profiles. Please refer to nokia website for details on how to install bluetooth profiles
Dec 26, 2007 | Nokia N72 Cellular Phone
Bluetooth and infared
check your imei and bt mac adress.if they are not paired,bt and ir port will not work.other thing that may be wrong is bt module itself,that got damaged after the fall of the phone
Aug 25, 2007 | Samsung SGH-D500 Cellular Phone
Pair Bluetooth Stereo
put the music player on and press down on the jogwheel, select 'Play Via' and change it to Bluetooth stereo headset. It'll prompt you to open the swivel and take you to the bluetooth devices screen where you select the correct device, it'll then prompt you to close the swivel and will start playing through your headphones :-) Is that what you mean?... It's a bit of a pain really :-(
Aug 04, 2007 | Samsung SGH-X830 Cellular Phone
Android Apps Logo
169 people viewed this question
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
