Question about Andis Agc Super 2-speed Clipper International 220-volt Dog Grooming Clippers
Problems Andis AGC 2
I have had my clippers for just about a year now.. and have been experiencing a few problems. My first problem is with my longer blades (#3) the lift up while I am grooming and will sometimes even pop off.I clean my clippers regularly, and even after a cleaning my blade with still lift. This has been happening for the past couple of months. Another issue I am having is with my shorter blades (#10 esp) They leave really predominant lines like if my blade was dirty. I make sure my blades are clean and when I switched clippers.. I had no issue with lines.
    Sergeant:
  • 266 Answers
Sounds like it's time to replace the clippers with something much better.
Posted on Apr 27, 2014
How do I find what model my Andis pet clipper is
On the back of the clipper it should say something like AG, AGR, or AGC does it look like any of these dog clippers Dog Clippers .
Has it got a power cable or is it a Rechargeable? Also age is a good clue?
Feb 04, 2014 | Andis AGC2 Hair Trimmer
Why is clipper over heating
Either your blades need cleaning and oiling or it's possibly a faulty armature without testing the clippers and part mentioned with a multimeter it's hard to say. Armature
Apr 01, 2013 | Andis Agc Super 2-speed Clipper...
Andis agc 2 not cutting very well
Yep as simple as that just make sure they are a well recignised sharpener otherwise you will waste your money. You can rule out a clipper problem if other blades cut ok. Clipper Blade Sharpening
Mar 03, 2013 | Andis AGC2 Hair Trimmer
I have an Andis AGC 2 speed and I cannot figure out how to get the blade on and make it stay on when I turn on the clippers.
Ok you should be connecting the blade whilst the clipper is on this will ensure the blade engages with the clipper correctly, simply push the front edge of the blade into the clipper untill the latch has snapped into place.
Aug 19, 2011 | Andis AGC2 Hair Trimmer
CisfI bought an Andis Pet clipper AGC 2 speed. Have 2 blades - 7FC and 10FC. have lost directions on how to change the blades - can you send me directions so I can print them?
With the clipper running, grasp the blade set by the edges and flip it down away from the clipper on its hinge. Simply slide it forward off the tang and slide another blade while the clipper is running. Snap it up toward the clipper and you're set.
Apr 10, 2011 | Andis Health & Beauty
I ohmed out the armature on my AGC clippers. There is an open between two adjacent pads, is the armature bad?
Before you test make sure your clipper is DISCONNECTED from the wall outlet. before testingYour Andis Master clipper , I would check the electrical cord for continuity, 2 check your switch for continuity, and last your magnetic coil for open field.
Mar 11, 2010 | Andis 01690 Hair Trimmer
Andis super Agr+ / Andis Agc super maintenance
There is little needed most componets such as the motor and carbon brushes are fairly complicated and should be checked when the units are serviced.
Keep an eye on the Blade Drive Assembly as with most clippers they wear on the sides causing cutting problems such as lines in cut fur and snagging blades, alternatively send them, to our Clipper Repair department.
Mar 01, 2010 | Andis AGC Super 22360 Hair Trimmer
I have a Andis AGC 2 speed clipper and it keeps shorting out
No need to replace the clipper they are usually well worth repairing.
This sounds like a problem with you power cable they are just under £10, try moving the cable in different directions around the rubber strain relief coming out of the clipper.
Sep 10, 2009 | Health & Beauty
Andis Super 2 Speed AGC Clippers - The blades get very hot !
Buy some Kool Lube (Oster) or Andis Blade Coolant. Both are aerosols. Your 2-speed runs faster, so your blades heat up quicker. Check them often by touching them to your inner wrist, and spray them when they are hot. A bonus is that the sprays also disinfect! (FYI a hot blade can badly burn a pet, so make sure you keep them cool)
Apr 09, 2009 | Andis 29745 Clipper Headliner Hair Trimmer
Andis Agc Super 2-speed Clipper International 220-volt Dog Grooming Clippers Logo
143 people viewed this question
Top Andis Pets - Others Experts
Ross Keen
Anglia Clipper...
adam adms
adam adms
Are you an Andis Pets - Other Expert? Answer questions, earn points and help others
