Question about Home Security
Chain binding and clicking on spreader
I just had my springs replaced and now my chain is making a clicking noise on top of opener. I have checked all the internal gear and worm gear and they are not damaged. Have removed chain and reset on sprocket no change. More clicks on the upward movement, It appears the noise is coming from the area around the chain spreader. Door does go up and down.Any thoughts?
  • 5 Answers
SOURCE: Sears Garage Door Opener Problem
The problem lies in the RPM sensor, most likely due to the interrupter cup assembly. The interrupter cup assembly is the black cap that runs through the RPM sensor. You may have forgotten to re-attach this piece or it is probably moving too far out when the garage sets in motion. To fix this, remove the cup assembly, unscrew the two screws on the top metal piece with a 1/8 allen wrench, push the metal piece as far in as possible and put the screws back on. This will give more room for the cup assembly to spin and be read by the RPM sensor. Hope this helps!
Posted on Mar 12, 2008
  • 118 Answers
SOURCE: Garage door opener motor doesn't work.
2 flashes is a safety eye issue, but you problen is most likely that the chain is not sync with the limit setting. Take the bottom off the gear and sprocket assemble and rotate center limit srew until it is in the same position as the trolley.
Posted on Jan 30, 2009
SOURCE: garage door opener will not work after gear replacement
Mhindo,
Check this link: http://www.fixya.com/support/t519365-sear_1_2_hp_garage_door_opener_replaced
Should help. Solution 1 did it for me. My comments are under username Otrand.
Posted on Mar 21, 2009
  • 3197 Answers
SOURCE: Liftmaster tries to close instead of open door
Remove the chain from the sprocket and then run the motor until the sprocket turns clockwise and stops. With the door in the closed position and everything attached to it, replace the chain and tighten. This will get everything back into sync. You will most likely have to tweak the up and down limits a bit. Do not over tighten the chain. It should sag just a little.
Posted on Oct 26, 2009
SOURCE: Lift master garage door opener.
power is on, the door will go up about 12-16 inches and stop, but with help it will go all the way up,but !!!!!! when i hit the button to make it go back down it only moves about 12 inches whats up with this!!!!!!!!!!!!!!!!!!!!
Posted on Feb 28, 2010
How do I remove the spindles on a 1967 Chevrolet truck
You really should get a manual or look for one at the library so you can see the pictures. First remove the shock absorbers. Basically, you need to remove the balljoint tapers from the spindle, but you need a spreader tool to do it because they are very tight. You back off he nuts several turns. Don't take the nut off the spring can come flying out as the lower A arm falls. This can be very dangerous. Use the spreader to make sure both tapers are free. Then support the lower A arm with a hydraulic jack apply enough force to slightly lift that side of the truck. Now you can remove the nut on the top balljoint and lift the upper A arm up till the spindle is free. Then you can remove the bottom balljoint nut and lift up the spindle and remove it. Now you have to contend with all the spring pressure that is pushing down on the lower A arm. Tie some good rope or chain around several coils on the spring. and tie that to the frame so when you lower the A arm it doesn't come flying out. Often times it is best to use a spring compressor. You often will need one anyway to get the spring back in. Be very careful.
Oct 08, 2014 | Vehicle Parts & Accessories
Tip
Mechanical System Troubleshooting for Stairmaster 4000PT Stepper
  1. Remove the side covers. WARNING: TO REDUCE THE RISK OF INJURY, DO NOT OPERATE THE MACHINE WHILE THE COVERS ARE REMOVED. DO NOT DEPRESS OR RAISE THE PEDALS WHILE ANYONE'S HANDS ARE INSIDE THE MACHINE.
  2. Remove the Poly-V belt and inspect the belt for cracks, fraying or any other unusual or excessive wear.
  3. Spin the alternator pulley to check the bearings. Replace the alternator if any clicking or grinding noises are heard.
  4. Inspect the alternator pulley for wear.
  5. Tighten the transmission pulley set screw to the flat side of the transmission output shaft.
  6. Remove the drive chain and inspect the chain for frozen links. Replace a chain with frozen links.
  7. Tighten the transmission drive sprocket set screw to the keyway in the transmission input shaft.
  8. Spin the transmission drive sprocket input 1 complete revolution. The transmission pulley output should turn 19 revolutions. Replace the transmission if any clicking or grinding noises are heard during rotation or the drive ratio is not 19 to 1.
  9. Remove the step chains and return springs from the main frame of the machine.
  10. Inspect the step chains for frozen links and the springs for corrosion. Replace a chain with frozen links and replace a corroded spring.
  11. Make sure that the step chain connection points pivot freely and have no vertical play.
  12. Remove the pedals, pedal arms, and leveling arms and lubricate according to the maintenance section of the manual.
  13. Verify that the clutch sprockets of the hub assembly spin freely in the forward direction and lock in the reverse direction.
  14. Inspect the hub assembly for wear. The drive shaft sprocket should not move up and down or side to side.
  15. Clean and lubricate the drive and step chains with 30W motor oil.
  16. Reinstall all parts, ensuring the proper tension of the Poly-V belt and the drive chain.
Stairmaster Mechanical System Troubleshooting for 4000PT
on Feb 25, 2015 | Stairmaster 4000PT Stepper
I have a Scott's "Easy
I am sorry to hear about the problem with your Easy Green Spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 877-465-5160 at your earliest convenience to check part availability. Hilary @Scotts
Sep 19, 2011 | Garden
I have 2000 ls , took eng apart and found cam chain broke. and wonder what cause it to break clean? nothing is bang up.should i place cam chain and that be it or there more to it?
Very rare that a chain breaks. I'd replace the chain and before closing it up, turn the engine by hand and see if anything is binding or frozen in the valvetrain. Also look carefully at the valve springs to make sure that no valves have bent. (if bent, most times the spring will not return to normal height)
May 16, 2011 | 2000 Lincoln LS
I have a 98 dodge intrepid 2.7L and i had a guy come over to help me replace the water pump and timing chain. after we took the timing chain off and replaced the water pump i noticed that he rotated the...
if he just turned the cams over by hand then i doubt that he damaged anything as if a valve was open when the piston came to top dead center then it would have stopped moving.the noise isn`t uncommon because the valves springs will make some noise as they are compressed and the rockers will make some noise as they move against the cam lobe and and the valves will make some noise as the valve spring forces the valve shut.if when you aligned the cam marks and they didn`t hit the pistons and stopped you from moving the cams and all timing marks are aligned then you should be okay to start the motor.
Apr 08, 2011 | Dodge Intrepid Cars & Trucks
Replace starter rope spring part no 545008013 on the poulan p3416 chain saw. How to get the spring coil seated in the housing, and then get the starter rope part on top of it.
Hook the spring at the inner mount, then wind the spring CCW until the spool assembly can be attached to the outer spring, then continue to wind the spool until the spring is about half-tight or so. It must be able to wind about three or four turns more without becoming 'bound' which would lock the spool and not permit return of the cord. When the spring is wound, wedge it so that the cord can be attached, the work the cord around the spool so that the outer end will only project beyond the cord port a little way. Pull the cord out to make sure that the spring doesn't bind at full extension, the apply locking pliers to the cord to be able to attach the handle. Melt the cord ends to prevent the knots from pulling out. Hope this helps!
Jun 15, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Vt500 c ticking sound. Cam chain tensioners pretty sure its the cam chain tensioner springs. lost their spring If its been making this noise for a while what else would i need to replace. cam...
You have a self adjusting cam chain tensioner. It is sold as an assembly. Take out the complete unit and replace it with a new one. The springs are not bad , the device that keeps the pressure on the tensioner is slipping causing a ticking sound.
May 16, 2010 | 1985 Honda VT 500 C Shadow
My Scotts 3000 spreader has a spring that closes the drop chute and it has broken. Is there a replacement spring available?
You can use almost any spring with the same or close tension. Lowes and Home-Depot carry an assortment of springs.
Mar 31, 2010 | Scotts Company Scotts& Accugreeen 2000...
Speedy Green Parts
Replacement parts for your model can be found at amazon, click here and take a look: Amazon com scotts lawn parts. I hope this was helpful. Cheers
Mar 18, 2010 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Home Security Logo
20 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
