Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How to take play out of rack & pinion steering
    Problem Solver:
  • 10 Answers
New pinion gear! - some are adjustable - to push the gears closer together - but I doubt it on a lawn mower
= new rack - Sorry
Posted on Dec 31, 2013
How to adjust steering on 1988 plymouth reliant?
if you have too much free play the rack & pinion steering maybe worn out and needs to be replaced as there is no adjustment on these like the older cars. you should check the rag joint as it could be worn. its located at the bottom of the steering colume were it connects to the rack & pinion steering. it looks like a small U joint.
Aug 16, 2014 | 1988 Plymouth Reliant
Rack & pinion steering replacement
DISCONNECT TIE RODS ENDS FROM WHEEL HUB, DISCONNECT POWER STEERING HOSE FROM RACK AND PINION, DISCONNECT RACK AND PINION FRON LOWER ENGINE COMPARTMENT
Feb 19, 2014 | 2003 Chevrolet TrailBlazer
STEERING WHEEL PLAY
There are a few areas in which play can develop. The tie- rod ends and mounts for the rack and pinion can wear out. Also the valving within the rack and pinion can leak fluid within the seals for the rods inside the rack and pinion.
It would be good to have this checked because when the rack and pinion rods are extended, they can sometime jam and fail to retract, leaving you locked in a turn to one side or the other.
Nov 11, 2013 | 1996 Mercury Mystique
How to remove rack and pinion from 99 chrysler lhs
There are few help links showing exact accurate procedure to replace Rack and Pinion. Click the link below and follow the procedure:-----
Pinion Seal Replace on Dodge Dakota? http://howtobyme.blogspot.in/2012/04/pinion-seal-replace-on-dodge-dakota.html
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota cruiser? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
Front Drive Pinion Seal Removal on Ford Explorer? http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange & Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion Steering Gear On 2007 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion Steering Gear on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack & Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
How to Replace Power Rack & Pinion Steering Gear on Mercedes Benz Truck? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to replace Power Rack & Pinion Steering Gear on Toyota 4Runner? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion Steering Gear Replacing on Toyota Land Cruiser & Sequoia? http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear Removal on Toyota RAV4? http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
How to Replace Power Rack & Pinion Steering Gear on Toyota Sienna? http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
Nov 23, 2012 | Cars & Trucks
Rack and pinion? have play in wheel no sign of leaks new power steering pump installed
Hi Gunny, If your vehicle is fitted with rack and pinion steering also check the rack ends for play. The rack ends are the rods which the tie rod ends screw onto. The other end fits onto the rack of the rack and pinion. To work on those you will need to remove the rubber boots and loosen the locking washer, they can then be loosened with a wrench. If they are worn the play will be evident in the steering. When replacing them also replace the rubber boots. If the boots are worn and road grime and dust enters, you will see leakage from the rack and pinion in the near future. I always thought the Dakota was fitted with a steering box? Regards John
Jun 24, 2012 | 1990 Dodge Dakota
99 Olds alero will only turn to the right. On quick inspection found that the rack and pinion moves with turning the wheels. Is it supposed to?
The whole rack & pinion does NOT move! Only the rod out of either end of it. If the main body, where the hoses connect, is moving the mounting bolts are missing, or broken.
Normally any vehicle with rack & pinion steering, that will not turn left equals a bad rack & pinion.
The "wont turn left" is the classic industry wide indicator that the rack & pinion is worn out.
Aug 21, 2011 | 1999 Oldsmobile Alero
My toyota camry steering went very stiff
Unless the rack and pinion gears are slipping (jumping a cog), then try putting oil on the universal joint in the steering column just above the rack & pinion. Two mechanics wanted to change the rack & pinion for $900 or the "Yoke" (whatever that is) but a generous squirt of oil on the U jont fixed the problem for my 2002 Camry!
Aug 11, 2011 | Toyota Camry Cars & Trucks
A little play in rack and pinion
IF RACK GOES OUT YOU HAVE EXCESSIVE PLAY IN THE STEERING DUE TO WORN RACK..OR POOR RETURN OF STEERING WHEEL TO THE CENTER.BEFORE BUYING A NEW RACK PINION.CHECK RACK MOUNTING BOLTS FOR LOOSENESS.CHECK RACK PINION MOUNTING GROMMET.ALSO CHECK FOR LOOSE WORN TIE ROD ENDS.IF WORN THEY WILL CAUSE PLAY IN STEERING WHEEL.
Jun 19, 2010 | 2000 Chevrolet Blazer
Leaking in power steering system on 2005 dodge grand caravan
Power steering fluid is leaking from the left side of the Rack & Pinion. Is there a way to repair it without replacing the Rack & Pinion?
Sep 28, 2009 | 2005 Dodge Grand Caravan
Steers as if it has no power steering
you will notice the rack and pinion if it is the trouble because when you steer the steering wheel the end play is very big because the specifide end of a steering wheel is only 25mm (+)or (-) 5mm.
then if the end play of the steering wheel go on the rack end pinion and look for other guy who can steer the steering wheel
so you can see the movement of the rack end pinion, one thing once the rack end pinion has a oil leakage i'm sure that the trouble was at that point but if no of what i have mentioned may be the trouble goes to the oil pump, but you can notice if the problem is on the steering pump it will create a noice ,hard to steer and you can see the oil will have a bubbles
for more info email me at
pochiemontejo63@yahoo.com
Jun 21, 2009 | 1999 Pontiac Grand Am GT
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
93 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
