Question about Music
Peavey pro 12 cpm - Music
I have a Peavey Impulse 200 speaker. The 12" speaker stopped working, but it and the circuit board look fine. What do I check now?
Disconnect the leads from the 12". Put a voltmeter across the speaker terminals and check for continuity. If it reads open, the speaker is dead.
May 16, 2017 | Peavey Music
Can you repair a tear in a peavey guitar amp and will it affect the sound
I have to assume you're really meaning a tear in the speaker cone. If so, yes you can repair it if it's small and yes, it will affect the sound. Peavey Bandit amps have come with a few different speakers over the life of the name, but all will still be available either online or directly from Peavey's parts department. Here's the link-
http://www.peavey.com/support/contactinfo
Oct 21, 2015 | Peavey Bandit 112 80W, 12" TransTube Combo...
Peavey pvxp p-12 speaker wont power on
RFeplace the fuse, then call Peavey Ciustomer Service.
May 12, 2015 | Peavey Music
Peavey problems
I assume you mean the Pr-12RX passive? That seems wrong to me, too. Put an ohm meter across the terminals of the horn driver and the woofer seperatly to see which, if either, is blown. If they're OK, look for a bad solder joint on the crossover.
Jul 28, 2014 | Peavey PR 12 Speaker PA Passive
Schematic peavey studio pro 40
Contact Peavey toll free at 877-732-8391.
Sep 30, 2012 | Peavey Music
Main Line in became unsoldered
What PEAVEY product do you have? we here at Pro Line Music are PEAVEY DEALERS and service center you can get in touch with us at servicedepartmentprolinemusic@comcast.net
Jun 10, 2011 | Peavey Music
Hello, What is the proper way to connect an Ashly XR1000 Crossover and a Pyle Pro PTA1400 power amp to my Peavey XR8600 so I can use 2 subs? The subs are not powered, but do have a passive crossover...
Here is a link to the manual:http://www.peavey.com/assets/literature/manuals/00513220_7.pdf I didn't look at the manual for the crossover but this is probably the way I would do it. Look at page 13 in the manual : Come out of the Main out (31 in the diagram) into the main in of your crossover. Go out of your crossover Hi and Mid out setting back into Power amp In 1 (labelled 32 in the diagram). Hook your speakers that you normally use to the output jacks on the back of the Peavey. Make sure you match the output impedances. Go out of your crossover low output into the Pyle power amp and out of the Pyle into your subs. Make sure the impedance ratings of all your speakers match the output impedances of your amps. You will only be running in Mono mode as that is the signal output of the Peavey mixer. You can run faux stereo by using the Main monitor Out as 1/2 the pair and the Main Out as the other 1/2 to both channels of the crossover but you won't be getting a true stereo pan mode.
Aug 22, 2010 | Peavey Xr 8600 8 Channel Powered Mixer
I would like a wiring diagram for peavey pro 15 speaker thank you
Here is their support page if it helps:http://www.peavey.com/support/ Also try this link:http://forums.peavey.com/
Mar 01, 2010 | Peavey Music
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
