Question about Panasonic SC-AK24 CD Shelf System
No audio in speakers only in headphones
All working good but no audio in speakers
  • Panasonic Master
  • 5,056 Answers
If inserting headphones before the fault caused the speakers to switch off. Then you should look to the headphone socket as the cause of the problem. It could be that inside the contacts have become bent out of shape. You might need to replace the headphone socket. If you can use a soldering iron you can do this yourself. Otherwise it's not an expensive repair.
Posted on Apr 24, 2013
  • Manolo Betancourt May 06, 2013
    I replace the headphone socket and the audio output was ok in the speakers thak 's for the help.
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
My laptop's audio software is installed correctly. it is working well in headphone but when i unpluged the headphone leaptop original speaker is not working
the problem is likely your speakers. consider the extension speaker or speakers use the function bound to perform troubleshooting
Mar 09, 2012 | Dell Computers & Internet
My headphones will work but my desktop speakers will not why?
If your speakers work fine when plugged into the headphones socket on the front of the system, then there is no fault with them.
If the sound through the speakers is very low when plugged into the rear panel socket, that would suggest that you may be plugged into the line out socket rather than the speaker socket and that there is a mismatch of the impedence between the socket and speakers.
If you have three audio sockets on the rear panel, try the speakers in the second output socket (but not in the microphone socket) and see if it makes a difference.
You could try the same test using the headphones - do you still get good sound levels with the headphones when plugged in to the rear panel socket?
If neither the speakers nor headphones give good sound when plugged in to the rear panel, then you may have a problem with either the sound card if the sockets are on a separate PCI card, or with a poor connection on the cable to the socket header bracket from the motherboard pins for audio for integrated adapters.
Dec 23, 2011 | HP Compaq dc5000 Microtower PC Desktop
One speaker doesnt work the other ones poor
Assuming its a PC:- The problem may be due to the audio part. Try different music files or sound sources. - If the problem persists, on a windows system, go to Control Panel>Sounds and check & control the settings there. - If continues, try a headphone/earphone. If the audio is still not good on different audio sources, try reinstalling the sound drivers. If the audio is good, check the cabling and connections of the speakers (between speakers and PC, between two speakers and the power line) - If after all, the audio is still bad ( and headphone sound is good), the speakers have a malfunction. Try the nearest computer fixing service.
Mar 10, 2011 | Computers & Internet
Do headphones NOT work in these speakers or do they have to be jbl brand headphones?
Not really, see the headphone connector if it fits the unit. If it fits but doesnt work then the headphones may have a problem. HOpe this helps and have a good one!
May 01, 2010 | HP JBL Platinum Computer Speakers
Sound through headphones only.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Apr 05, 2010 | M-Audio Studiophile DX4 Computer Speakers
My speaker all of a sudden stopped working, they are built into my monitor, and worked last night. what do i do?
  1. Check the volume control in windows and make sure audio was't muted
  2. Check the audio cable and ensure it is connected to the port on the system
  3. Ensure headphones are not plugged in an aux audio port as they will mute the speakers
  4. Check the audio drivers in Device manager
  5. Try a known good set of speakers (Or CD player headphones) and ensure the audio on the system if functional
  6. If all else fails, replace the speakers ($20 or less at any major department store)
Oct 14, 2009 | Dell E153FPT 15" Flat Panel LCD Monitor
Compaq presario. speakers wont work but headphones will
Apparently the built-in speakers have one bad. You can have the speakers replaced for you at a good computer repair shop if you cannot affort to send it in at this time.
Oct 05, 2009 | Computers & Internet
Audio problem...
i have compaq presario c700. when i attach headphones, the laptop speakers dont get off. both headphone and speaker are on. the sound should only come from headphones..
i have windows professional installed
ishric_ishaan@yahoo.com
kindly post the feedbakc on my email
May 26, 2008 | Intel Computers & Internet
Using headphones with Logitech X-230 speakers
I really don't know, because some of the newer gadgets come with fixed volume control due to law suits, ect. Try to see if you can bring you TV menu up and see what the sound setting is.
Dec 25, 2007 | Logitech X-230 Computer Speakers
Panasonic SC-AK24 CD Shelf System Logo
56 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
