Question about Ingersoll Rand Air Tools & Compressors
WIRING DIAGRAM
ELECTRICAL WIRING TO STARTER AND MOTOR
  • Ingersoll Rand Master
  • 15,695 Answers
What is the model number?
Posted on May 06, 2013
2003 ford e250. Won't start turn key and just clicks 2 times and then everything shuts off. I have replaced ignition switch and lock cylinder and still doesn't start
Testing the electrical circuit's is the best way to find the problem ! Voltage drop testing ! Reading factory sevice info. learning how to trouble shoot the problem , not replacing parts .Do you know what a wiring diagram is ? How to use one to find point's in an electrical circuit to test at ? Here is a web site for free wiring diagrams . http://www.bbbind.com/free_tsb.html Enter vehicle info. year ,make , model and engine size . Under system click on engine ,then starting in subsystem . Click search button , then the blue link . There is the transmission range switch , the starter relay etc.. you have connection problems or the main battery cable to the starter.
Starter Voltage Drop
How to voltage drop test starter motor circuit
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
watch these videos , buy a volt meter an test the electrical circuits .
Do you know what the relay switch is ?
The starter motor solenoid relay switch:
  • controls current to the starter solenoid.
  • is engaged by the ignition switch.
  • connects the battery (10655) to the starter motor.
The TR sensor on automatic transmission-equipped vehicles prevents starter motor engagement unless the transmission is in the NEUTRAL or PARK position. For additional information, refer to Section 307-01A or Section 307-01B .
Jun 23, 2017 | Ford Cars & Trucks
My 1999 mercury grand marquis does not turn over. I replaced the starter and the pulleys still do not turn at all. What can it be ? Any suggestions ?
Do you know how to test automotive electrical circuit's ? Starter circuit voltage testing ? Do you know what all is involved in the starter circuit ? Do you know what a wiring diagram is ? How to read a wiring diagram ? Replacing parts without testing is not the way to fix automotive electrical problems , And if you don't know how to test the electrical you learn how , or take it to a qualified repair shop . How to voltage drop test starter motor circuit
you can view a wiring diagram at http://www.bbbind.com/free_tsb.html
Mar 21, 2017 | Mercury Cars & Trucks
Tryed to start my 2002 s-10 4.3,it clicked one time then i lost all power.put in new battery and changed 175 fuse,cleaned all ground connections and still no power.
Test with a DVOM - digital volt ohm meter , find a power distribution diagram an check the flow of Voltage . Do you know how to do basic automotive electrical testing , how to use a DVOM , how to read a wiring diagram ? Electric Testing Techniques You Need to Know
Copy of Voltage Drop Essentials TST Motor Age
You can find free wiring diagrams here http://www.bbbind.com/free_tsb.html
There is no guessing in automotive electrical system repair !
Check main B+ cable to the starter .
Mar 18, 2017 | 2002 Chevrolet S-10
My 2002 volvo s60 shut off while i was driving and now all it does is click like my batterie is dead..i bought a new batterie and even tryed to jummp it , but only a click
Could be a bad battery cable or connection ! If it clicks it must be getting some voltage . A voltage drop test of the starting circuit would be the thing to do . Starter Voltage Drop buy yourself a volt meter . How to voltage drop test starter motor circuit . Find wiring diagrams for your vehicle , not all car makers do it the same way . http://www.bbbind.com/free_tsb.html free wiring diagrams . Watch videos on basic automotive electrical testing , how to read a wiring diagram . Then test the electrical circuit of the starter system .
Jan 28, 2017 | Volvo Cars & Trucks
94ford probe won't start
Well Sandra , the thing to do would be to get it to turn the engine over with the key , Then diagnose the no start problem . Look at a wiring diagram (do you know what that is ?) When you turn the key to start , the electrical part of the ignition switch sends B+ voltage to the starter interrupter relay through the clutch switch to the starter motor solenoid . Testing the electrical circuit with a DVOM - digital volt ohm meter with the help of a wiring diagram ,so you know where to test is the proper way to diagnose the problem . Not guessing ,an rigging the stuff . You can find free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model an engine ! Under system click on engine ,then under subsystem click starting . Click the search button then the third blue link .
Do you know what a relay is ?
VEHICLE RELAYS Testing from the relay base
VEHICLE RELAYS Operation Diagnosis
If you look at the wiring diagram you will see the relay is controlled by the CPU - engine computer .
Jun 29, 2017 | Cars & Trucks
Starter wiring
was it the battery positive cable or a smaller wire. possibly a fusible link wire go online with year,model,and engine size of your vehicle and search for electrical wiring diagram even more specifically all wiring going to the starter motor
Feb 18, 2014 | 1992 Volkswagen Jetta
I need a electric diagram of a XT600 89 or do u know where is the starter cable.?
The starter motor cable is the thick wire from the starter motor from the starter solenoid the other thick wire from the solenoid goes to the battery
Ride Safe
Bike-Doc
Please rate this answer
Dec 05, 2010 | Yamaha XT 600 E Motorcycles
Yamaha Maxter Xq125, the electric starter motor will not operate
I looked all over and could not locate a wiring diagram for your bike. Typically, there is battery voltage to only one of the large cables attached to the solenoid. The 'hot' one comes directly from the positive side of the battery, while the other cable goes to the starter motor.
It sounds like the starter solenoid is bad. To find out, simply bridge the two large cables attached to it using a large screwdriver. If the starter spins when you do this, the solenoid is bad. If the starter doesn't spin, then the problem is either the starter motor, or the cable that goes to it.
Dec 09, 2009 | Yamaha TW 125 Motorcycles
2000 classic no power to starter , wiring diagram
Below is a diagram of the electric starting system of your Yamaha. I have a couple of tips to help pinpoint the problem. First, check to see if there is battery voltage to the starting relay. If there is, use a large screwdriver to bridge across the two large cables attached to the top of the relay. If this causes the starter to spin, then you've got a bad relay. If there's voltage to the relay, yet the starter does not spin when you bridge the two contacts, then you've got either a bad starter motor, or a faulty electrical connection between the relay and the starting motor.
If the starting relay does not make a clicking sound when you push the starting button, then you've got either a defective starter button, or wiring goin to the relay. I hope this is helpful.
Dec 04, 2009 | 2001 Yamaha V Star Classic
Air Tools & Compressors Logo
148 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
