Question about Car Audio & Video
Sony hcd gn90d
POWER LED BLINKS
SOURCE: Sony KV-32FS120 blinks 4 times
good day.
Have you tried first resoldering the terminals in the circuitry?
Also, try to check for the ABL supply near the flyback. Watch out for the small voltage zener diodes.
response is highly appreciated.
chris
Posted on Mar 28, 2008
  • 7 Answers
SOURCE: Sony green power/standby led blinks picture goes out
I had this same problem and after doing some research, I removed the lamp, cleaned it and plugged it back in. It fixed my problem completely.
Posted on Mar 30, 2008
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
Posted on Mar 04, 2009
Slinteriors
  • 8617 Answers
SOURCE: red led blinks 5 times.
The lamp driver ( Ballast) is faulty
Posted on Jun 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: SONY HCD LX-50 msg: "Power down to Protect"
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 03, 2011
No display ,no sounds standby only
no display ,no sounds standby only
my sony hcd-gn1200 no display stanby led only
Jan 22, 2014 | Audio Players & Recorders
Sony system hcd-zux9 shots off power button flashing
My Sony - Model : HCD-GX 470 . When i turn the power on it is on . Just 30 seconds it turns off itself . I do not know what is going on ? Please show me OR help me to fix it .
Jan 06, 2014 | Sony MHC-GX450 CD Shelf System
Sony mhc-gn90d frontpanl touch button not working
If under warranty, contact Sony. If out of warranty, then you need to replace the microswitch. Involves soldering, heat, wires, remove and replace, obtaining a new switch...save the headaches and take it to a repair shop.
Oct 05, 2013 | Sony MHC-GN90D Shelf System
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
Sony TV Model Number: KV-27FS100L No Power 1. Stand By LED Blinking Three Blinks No PowerIntermittent. 2. Stand By LED Blinking Three Blinks No Power Intermittent. 3. Stand By LED Blinking Two Blinks No...
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Apr 07, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
