Question about Dishwashers
Kitchen aid dishwasher
Fills up with water between cycles from below.
  • pablo sandoovall Apr 29, 2013
    you can also use this link and see if this helps.http://www.doityourself.com/forum/electr...
  • melinaholsin May 06, 2013
    the water is clear not dirty . do you still think it is the float level?
    Master:
  • 435 Answers
The washer is filled up with water because it is at float level. So basically same water to clean again and again. You will have to remove kick panel at the bottom front for access to the pump and drain hose.
Posted on Apr 29, 2013
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Posted on Feb 22, 2008
  • 7 Answers
SOURCE: Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Posted on Jan 21, 2009
  • 2976 Answers
SOURCE: My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Posted on Apr 06, 2009
  • 530 Answers
SOURCE: Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Posted on Apr 14, 2009
  • 3 Answers
SOURCE: Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Posted on Apr 23, 2009
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a Kitchen Aid Superba KUDS24SEBS1. The inlet water pressure is good and the dishwasher fills and starts the wash cycle, however, after the initial spray of water, it seems that all of the water...
when "full" of water, the normal height of level is about 1/2 below the heater assy(large blackish grey coil below he spray arm).. if theres enough water in the unit nad its still not "spraying",its quite possible that your filter/chopper assy is clogged and cant let water through. try removing hte spray arm and under that you will see 5 torx15 screrw holding down top filter plate under there to the left youll see another t15 screw covering hte chopper assy area. claen out sump of debris this may be your issue
Nov 26, 2008 | Dishwashers
Kitchen Aid Superba Dishwasher
check the holes in the spray arms to see if they are plugged also brand and model number will help
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Feb 21, 2008 | Dishwashers
Dishwashers Logo
101 people viewed this question
Top Dishwashers Experts
Owen Barnes
