Question about T-Mobile Sidekick
I'm trying to use my camera.but there is a message low memory.no photos.
    Problem Solver:
  • 14 Answers
Do you have a memory card if not you most likely have alot of contacts and if not that then could be a software problem Good luck let me no Jonny
Posted on Mar 13, 2009
Memory Error
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Sep 30, 2012 | Pentax X70 Digital Camera
When trying to take a photo a message, "memory
The camera is asking you to format the memory card, you should find this in the camera menu format or initialize are the same thing. Also what may have happened if it's a new memory card is that the locking switch is in the wrong position I'll include a diagram to show the proper position for this switch. I'm sure once you have corrected the switch position and formatted/initilized the car all will be well.
Diagram
Mar 02, 2011 | Fuji FinePix Digital Camera
Internal memory is full
Good day,
The internal memory full message will display when the camera has no more space left to save photos.You can either download the photos to a computer at home or write the photos to a cd and erase the memory to be able to take new pictures.
You can also buy a SD Card that can be used as extra storage. A 4Gig card would be a nice size to add to your camera as it will take a while before you will run low on storage again.
Hope this explains your question!
Regards
Dec 01, 2010 | Kodak EasyShare C633 Digital Camera
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Card error
If you get a message as "Memory Card Error" on your camera AND you still need some of the photos , the first step is to format the card through the camera menu (Note: if you have an sD card, once you re-format your card any photos cannot be recovered.). check your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
To format* a memory card:
(*instructions on formatting memory cards can be found in your camera's user manual) you equally format the card using your computer if the above method fails,if the micro sd card is inserted into the sd slot of your system the computer sees it as a storage device in that way you can format it the usual way you can format a drive on your system but mind you if you have valuable pictures on it ,they will be lost but in that case you can use the low level format utility
Jan 06, 2010 | Olympus SP-700 Digital Camera
How do i take more than two photos
I also have this camera the answer is actually pretty simple you just need a memory card
Jan 03, 2009 | Polaroid i735 Digital Camera
Message Display
sometimes this problem occures due to defective or fake memory media. try using a good branded card.
Sep 09, 2006 | Panasonic Lumix DMC-FZ10 Digital Camera
Error code messages in the status panel of the Fun! Digital 320 camera.
The following is a listing of the error codes you might see on the status panel of the PhotoMAX Fun! Digital 320 camera: 1.FL - Photo memory is full. You cannot take more photos. Download and then erase the photos in your camera. 2.FE - Flash memory error. A camera hardware error occurred. This can happen when the power is shut off before a photo is completely stored in the camera. Do not shut off the power until the green light comes back on steady after you take a photo. 3.bE - Hardware problem. Turn the power switch on and off and see if the error message disappears. If the error message persists, the camera may need to be replaced. 4.Lo - Battery low. Replace the camera battery as soon as possible. If you continue to use the camera, picture quality will be poor. 5.LL - Low light condition. The camera does not have enough light to take a good photo. Improve the subject lighting if possible. Example: When taking indoor photos, add additional room lighting.
Sep 21, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
T-Mobile Sidekick Logo
46 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
