Question about Kenmore 62702 Microwave Oven
Just quit while cooking. No power in unit.
Just quit while cooking. No power in unit. Nothing works.
  • mrrwlr May 11, 2010
    How do you get the fuse in the back?
    Sergeant:
    Champion:
  • 234 Answers
Check for fuse in back of unit.
Posted on Mar 13, 2009
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Model #
Make and model will usually be on a label plate on the back of the unit.
With the age of the unit and unlikely availability of spares you may be better to look for a new unit. Cheers, Dan
May 08, 2012 | Microwave Ovens
While cooking a potato the unit just quit heating. Still sounded like it as working but no heat
Sorry to read about your problem.
It seems your have a general failure in the power control or switch failure on the unit. if your unit has power, and things lite. it is more likely you have a control/switch problem,
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | GE Microwave Ovens
Hi I have bought a new Prestige Induction cook top. I have been using it for quite some time, but without any problem. All of a sudden today when I try to heat water , the temperature panel goes to E3...
I have bought a new Prestige Induction cook top. I have been using it for quite some time, but without any problem. All of a sudden today when I try to heat water , the temperature panel goes to E3 and nothing else works.
In order to start it again I have to switch off the power and start all over again.
Please help me in fixing this problem
Oct 28, 2010 | Microwave Ovens
My PVM 1870 GE microwave doesn't cook anymore. I received a temp sensor error message once and it quit heating. The transformer and capacitor check good. I believe the magnatron is also good. Any...
If the cook light is working and there is power to the transformer, DON'T try to measure the secodary voltage, most meters do not read that high.
You say the capacitor is OK then there is nothing else but the magnetron to suspect.
Change the magnetron if all else is OK.
Oct 18, 2010 | GE Microwave Ovens
The microwave wont respond to the timer. It keeps cooking unless you open the door. After the timer runs out it seems like it cuts off but there is still a low buzzing sound and it is still cooking. Have...
low buzzing can be a power relay or a (solid-state)
triac which both supply power in their own right to the power transformer to operate the magnetron tube,even though you say it quits cooking when you open the door,i would still check the micro-switches in the door for proper alignment and operation, because it can be a door switch mis-alignment or a leaking triac still supplying power to the unit
Jul 14, 2010 | Kenmore Microwave Ovens
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
GE SpaceMaker JVM140001 just quit
Same thing happened to our unit. My wife had started cooking potatoes and we left house for an hour. Came back and unit was dead, nothing worked. Verified power @ plug. Unplugged, pulled control panel and checked fuse which is mounted @ top of circuit board (will now refer to as CB), back side of interface panel. It passed continuity test. Inspected wiring and was all intact, no sign of burn thru. Varistor visual also looked good, no discoloration or burns. Removed (5) fasteners that hold CB to interface and inspected back side. Noted minor "blackening" @ pin location #1 of the (5) pin plug immediately beneath fuse. Resoldered because connection looked poor. Plugged back in and tested, all features worked correctly!
Mar 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Express cook doesn't heat. Time cook seems to work at least sometimes
Oct 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Runs but wont heat up
Probably magnatron is bad. Best test is to substitute a known good one. There are others but you are in the 4000 volt area of the unit.
Aug 06, 2006 | GE JES1039 Microwave Oven
Kenmore 62702 Microwave Oven Logo
117 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
