Question about Quinton Stairmaster Clubtrack 3.0 GymTough Walking Belt
TREADMILL I HAVE A QUINTON CLUB TRACK 3.O TREADMILL WHICH A BOUGHT AT 1994. I AM PRESSING THE RED RESET BUTTON AT THE BACK OF THE TREADMILL BUT THE TREADMILL DOES NOT RESPOND AND SHOWS THE MESSAGE "PLOS". THE RESET BUTTON IS NOT THE PROBLEM.I KNOW THAT BECAUSE I REPLACED IT WITH OTHER BUTTONS AND I TRIED TO START THE TREADMILL BUT THE OUTCOME WAS THE SAME.I ALSO REPLACED ALL THE ELECTRONICS INSIDE THE TREADMILL..,NOTHING HAPPEND AGAIN SHOULD I CHANGE THE WIRE?
Nordic track A2350 treadmill, I found this unit with lights blinking this afternoon, so I unplugged for 1hr and when plugged back in the only thing that happens is the red iFit logo comes on. What can I...
reset the treadmills, follow the steps and fix it.
God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 18, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
Tip
How To Calibrate the Lift Motor on Quinton ClubTrack Treadmill
The following describes the steps required to calibrate the lift motor on a Stairmaster (Quinton) ClubTrack.
  1. Enter service mode on the treadmill by using the following keys at the same time:
    • Faster - Slower - Stop Belt
  2. Allow the lift motor to free spin by removing the bolts from the metal block on the jack screw.
  3. Press the up arrow on the control panel until the incline is at 5% then press the down arrow and take it back down to 0%. This will allow the lift motor rheostat to find its range.
  4. Spin the metal block on the jackscrew to allow 1 - 1.5 threads to be exposed from the top. Secure the lift motor back to the frame by inserting the 2 bolts through the bracket holes and into the metal block. NOTE: Double check the spacers on each side to make sure they are flush.
  5. Run the treadmill incline up to 15% and check the jackscrew to verify it has not bottomed out before reaching 15%. There should be around 4 - 6 threads exposed. Bring the treadmill back to 0% where there should be the same amount of threads exposed from the top of the jackscrew. If you see the correct amount of threads the lift motor is calibrated.
NOTE: If there is an error on the display panel, ex. E211, you need to manually turn the jackscrew back to 0%. To perform this unscrew the 2 bolts from the bracket securing the metal box and jackscrew allowing it to freespin. Use a shop rag or towel to wrap around the jackscrew to prevent damage to the threads. Using a pair of pliers (channel locks or vice grips recommended) manually turn the jackscrew back to 0%. Once this is accomplished run through the above steps to perform the calibration.
Quinton Treadmill Support How To Calibrate the Lift Motor
on Mar 10, 2015 | Quinton CLUB TRACK Treadmill
Code e207 stairmaster club track
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
E207 is an error indicating "Moderate Motor Overcurrent". This occurs when either the user is out of the maximum weight range or there is excessive wear on the deck or running belt. The following link will take you to the parts and other information we have available on the club track.
Stairmaster Quinton Treadmill ClubTrack 612 612 Parts SPORTSMITH net
Jul 08, 2013 | Exercise & Fitness
Quinton treadmill E203 error VSD Lower Board
Quinton E203 Error, Motor Overcurrent (Overload) Probable Cause 1. Obstruction to motor pulleys or belt
2. Disconnected or loose motor lead
3. User outside the weight/speed envelope.
4. Excessive wear to deck/belt.
5. Motor.
6. Lower Electronics.
Corrective Action Quinton Treadmill Models: Club Track 3.0 and Hyperdrive
  1. Inspect for obstruction and remove if necessary.
  2. If the motor did not turn, inspect for loose or disconnected motor lead. Reconnect if necessary.
  3. Restrict users to weight capacity of unit. Restrict use to people that do not move slower or faster then speed setting.
  4. Inspect deck and belt condition. Deck should have a slick smooth surface, free of nicks, grooves, or rough areas. Deck should be flipped or replaced if necessary. Underside of belt should not have a hard glazed appearance. Belt should be replaced when deck is flipped or replaced.
  5. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If unit operates and then error appears again, replace drive motor.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is greater than 100 ohms, the motor needs replaced.
  6. Club Track 3.0 models: Remove power and allow unit to cool for 15 minutes. If error message appears immediately, replace the lower electronics.
    Hyperdrive models: Remove power and wait for high voltage indicator to go out. Check resistance between motor leads. If the reading is less than 100 ohms, replace the lower electronics.
Quinton Treadmill E203 Error Code
Feb 20, 2013 | RTO Stairmaster Clubtrack 510 Treadmill
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
  • 3
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
E203 error message when i press start button
5. Motor.
Jan 09, 2013 | Exercise & Fitness
Quinton treadmill error 203
5. Motor.
Jun 16, 2012 | Exercise & Fitness
Quinton clubtrack treadmill shows E203 code, says drawing more than specified current. Could it be a bad motor?
5. Motor.
Dec 06, 2011 | RTO Stairmaster Clubtrack 510 Treadmill
QUINTON CLUB TRACTURNED MACHINE ON..THOUGHT IT WAS 220 VOLTS..SAW
This is most unfortunate if this either club track 510 or 612 your out of luck the electronics are no longer available. If these are either 510 or 612 you can get it repaired call National Gym Supply @ 1-800-496-7278
Jan 29, 2010 | Exercise & Fitness
I have a quinton club track treadmill that posts an E203 error
E203 = Motor unable to run. Usually caused by the VSD Lower Board. This board is about 14" square on a Quinton Clubtrack Hyperdrive 3.0
Rather difficult to remove escpecially if your not familair with electronical compnents in a tight space.
My reapir coast $374 from J&R Technical Services and exactly one year later I got the exact same code. Warranty is 90 days.
It appears they rebuilt one of the components on the board called a Phase Modulator. There are three of them. They stated they had replaced it, but upon close inspection it appears that simply replaced the bad micro-component on the modulator and reinstalled the exact same phase again.
I'm debating whether to trust them once again. Little choice though since they control the market and have the equipment to reset the board upon repair. Nobody at thome has this equipment.
Sep 15, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
Quinton Stairmaster Clubtrack 3.0 GymTough Walking Belt Logo
Top Quinton Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Quinton Exercise and Fitnes Expert? Answer questions, earn points and help others
