GOODMAN CPKE 30-18 - Heating & Cooling
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Oct 10, 2016 | Goodman Heating & Cooling
I have a Goodman A/C unit model number cpke 36-1a. My problem is that the fan in the house works along with the unit fan outside, but no cold air in the house. What do I need to check? thermostat is set at...
First check the filter to see if it is not completely clogged and make sure the
coil fins behind it are not frozen solid. If it is then shut off system or switch it over to
Heat to defrost the coils if you have a heat pump, then replace the filter.
Then check the outdoor unit to see if the large copper line coming to it is cold
(this means the compressor is running and not just the fan)
Also Make sure the thermostat is in "AUTO" and "COOL"
The last thing to check is to make sure the duct work to the return has not separated or
has not been torn open by animals (cats love to do this under mobile homes).
Sounds like a ductwork problem or plugged filter from what you describe. Hope this helps.
Aug 10, 2011 | Heating & Cooling
I WANT THE WHOLE CODE FOR THIS
This whole code for above we can not give.
Aug 06, 2009 | Shopnovell iFolder 1.0 Software Media Kit...
Goodman gas furnace power vent motor and housing replacement
You need to type GOODMAN GAS APPLIANCES into you browser to find you local servicecenter. I must tell you that Goodman only sells to authorized service companies in my experience. So you become EgKraft Company.
Nov 07, 2008 | Goodman GMS90703BXA Heater
Goodman a/c unit
Look at this forum and others as well. You will see many issues with Goodman products. Believe the old saying "You get what you pay for!". Carrier, Trane / American Standard, Payne.
May 27, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
