Question about Huawei u8661 dual sim
For can't use bluetooth and wifi in my phone
I can't use bluetooth and wifi.
Mac-address wifi unavailable and bluetooth address unavailable.
- go to data/misc/wifi (required root)
-backup file wpa_supplicant.conf in this folder which contains usename and password wifi
- delete all file in this folder
- turn on wifi ( if you careful, you can reboot )
- now you can connect to wifi
- recovery file wpa_supplicant.conf
Sep 12, 2016 | Huawei P8 Cell Phone
Cant connect to wifi because bluetooh is stuck running a prograhm
You can turn off BlueTooth by either going to Settings-->Bluetooth, or touching the BlueTooth icon in the Control Center (swipe bottom to center to bring up the Control Center).
Test your WiFi. If it doesn't work, double-click the Home button, locate the program BlueTooth is running, and swipe it to the top of the screen.
Test WiFi again. If it doesn't work, power down; wait 5 minutes; and power up your phone (if you don't see the white Apple icon when powering up, you did not power down properly).
Feb 15, 2015 | Apple Iphone 4s I Phone 4 S Factory...
Wifi is grayed out
Turn off Bluetooth in settings and then tap wifi turn off then back on. Wifi should now be working
Jun 21, 2013 | Computers & Internet
How can i retrieve my massages from another phone
Hi, well to get messages from another phone, that phone must be able to be accessed from the other.. there is software available that allows one to completely control another phone via, Bluetooth and WiFi, installing a client on one phone and a master on the other should allow access to the "remote' unit, then you could do as you want. Another way is to Forward, just like an Email, any messages on to another number this too will work.
Have a look at this master search link, for the remote control software and choose one that you like that suits you... If BT isn't what you need, then look for a WiFi or Cell version
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=control+remote+phone++via+bluetooth
Sep 14, 2011 | Blackberry Curve 8350i
My Laptop specifications are, ASUS F80Q, dual core, 3 gb ram, Windows 7 ultimate. when i first installed windows 7 (long time ago) it detected my bluetooth device, but now in the middle suddenly it...
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
Jun 29, 2011 | ASUS F80Q-X2AM Notebook
Hello, I just purchased an acer tablet, and I'm trying to connect and use my wifi from my mytouch android cell phone, but its not connecting. What am I doing wrong?
you cannot connect two mobile devices because that two devices are only receivers so you need a transmitters such as the laptop or a wifi router and then using that you can connect your two devices
Jun 12, 2011 | Acer Computers & Internet
Phone turns off all the time and gets hot did a reboot but did nothing
Does this phone have a WIFI connection? If it does, check to be sure that it's not constantly on.
In fact, turn off your bluetooth, WIFI, GPS, and any other unecessary items.
This will save your battery and prevent drain.
If that doesn't work, You may need to get a replacement phone through your carrier's warranty program.
May 09, 2011 | HTC Desire Cell Phone
Hi, This is Michael here. I have bought Samsung Wave S8500 in mid Oct 2010. I'm having a problem with my wifi & bluetooth too. I have upgraded the latest firmware. 1. Whenever i turn on the wifi in...
Hello ,
I have the same problem. It just happen lately that I can't use wifi and bluetooth in my Samsung wave. I tried factory reset and still, I have still that problem.
Thanks,
Leonard
Jan 06, 2011 | Samsung Wave S8500 Smartphone
Is wifi is compatible for N73?
N73 does not have the hardware to connect to wifi but still u can
Try this...
1. Buy a bluetooth dongle.
2. Connect the bluetooth dongle to your laptop and enable bluetooth in N73.
3. Get internet in N73 through laptop.
(More info : http://web.singnet.com.sg/~kinston/Bluetooth%20Internet.htm)
U will not be able to connect to public wifis only to ur laptop...
Mar 08, 2010 | Nokia N73 Cellular Phone
Huawei u8661 dual sim Logo
20 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
rostit
 Brian Main
Brian Main
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
