Disconnected system to install new carpet now i'm stuck
Can't remember how to reconnect
  • 61 Answers
Try these...
1. Identify the Video out,Audio Out ports of the player. Normally they will be marked as AV Out for video,L(Left Audio) and R Out.
2.Identify the Video In,Audio In ports of the TV
3. Connect AV Out from the DVD to the AV in of TV,Audio Out of the DVD to the Audio in ports of the TV.
4.If the TV is Mono (means, with a single Audio in), connect to any one of the Audio port of DVD.
Posted on Mar 13, 2009
Yamaha soundbar
Remove the batteries from the remote. Push all the buttons to eliminate a stuck button as a cause. Reinstall the batteries or install new batteries. Disconnect and reconnect the soundbar. Check operation. If the problem remains, you may need to replace the remote
May 24, 2013 | Audio Players & Recorders
How to remove rear speakers
you have to removed carpeted surface covering speakers, be sure to disconnect wires befor doing this and taping them off so you will not blow a fuse, or short circuit radio, after cover is removed there should be 4 screws in each speaker, remove and replace, use light tester to determine positive and negative wires and reconnect and install new speakers.
Dec 13, 2011 | 1998 Pontiac Grand Prix
I dont remember power on password for hp nc4400
The power-on password prevents use of the computer until the password is entered. The
setup password prevents unauthorized changes to Computer Setup. To clear the
passwords, you must remove all power from the system board. If you do not know the
passwords, use the following procedure to clear the password:
1. Remove all battery packs.
2. Disconnect the AC power.
3. Remove the real-time clock battery.
4. Wait thirty minutes.
5. Reconnect the AC power. DO NOT INSTALL THE BATTERY!
6. Restart the computer. During Power-On Self Test (POST), a ? 162 System Options
not set? message appears.
7. Shut down the computer, then disconnect AC power again.
8. Replace the real-time clock battery.
9. Install the battery pack(s).
10. Reconnect the AC power.
11. Start the computer.
12.It should work....
Apr 08, 2011 | HP Compaq nc4400 Notebook
How do I replace the thermostat
3.1L Engine
  1. Disconnect the negative battery cable.
  2. Partially drain the cooling system into a suitable container, to a level below the thermostat.
  3. Disconnect the radiator hose from the thermostat housing.
  4. Unfasten the thermostat housing bolts.
  5. Remove the housing. Note the installed position of the thermostat, then remove the thermostat and gasket.
  6. Thoroughly clean the gasket mating surfaces.
See Figure 2
Fig. 2: Exploded view of the thermostat and housing assembly
To install:
  1. Position the new thermostat in the manifold.
The pellet MUST go towards the engine.
  1. Install a new gasket, using sealer as necessary.
  2. Install the housing and secure with the retaining bolts. Tighten the bolts to 25 Nm (18 ft. lbs.)
  3. Reconnect the radiator hose to the housing.
  4. Replace the coolant. Check for leaks.
  5. Connect the negative battery cable.
Hope helps (remember arted this).
Aug 12, 2010 | 1999 Pontiac Montana
Bissell proheat 2x carpet cleaner 9200 How do i
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
Jul 22, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Need Instructions on removing and replacing a fuel pump for my 2000 daewoo leganza
Hello martin09canc: First thing to do is relieve fuel pressure in the fuel system. Remove the rear seat cushion.Remove the access cover. Disconnect the electrical plug.Would not hurt to disconnect the negative battery cable. This would eliminate any sparks. Remove the sender retaining ring. Lift out the sender unit. Be careful not to spill gas on the carpet. Replace the seal and reverse the operation to install new unit. If you need further help please just ask. Please rate the quality of the answer as it also helps. Thank You for using FixYa. Roger
Apr 16, 2009 | 2000 Daewoo Leganza
Liking flude out of heater core how to fix free instructions
actually, the only way to fix this delicate piece of machinery is to replace the whole heater core unit. its the safe and best way. here are some step by step instructions on how to remove the old one. i also included instructions for installation of the new core as well. a fix ya rating would be most appreciated.
Remove the Old Core Step1 Drain the cars engine coolant from the water pump (remove the surge tank cap and drain bolt). Disconnect the heater outlet and inlet hoses by removing the clamps. Step2 Disconnect the Body Control Module. With the battery disconnected, parking brake on and transmission in Neutral, detach the entire front console, pull back the carpet to the right of the left dashboard support bracket and remove all the BCM's connectors and retainers. Step3 Pull back the carpet below the left dashboard support bracket. Remove the gas pedal from the front of the dash, then remove the center floor outlet ducts. Disconnect the main center floor duct from the heater/air conditioner module. Step4 Remove the heater core cover, from the HVAC module, sliding it away from the module locating pins and rearwards until the drain tube clears the dash front. Remove the heater core from the cover. Install the New Core Step1 Install the new heater core and reconnect the core cover. Use a new drain tube seal on the drain tube. Spray the core seal and dashmat with soapy water to make installing easier. Step2 Reattach the center floor ducts and the gas pedal. Install the Body Control Module and the front console. Step3 Connect the outlet and inlet hoses to the heater, replace the surge tank cap, fill the cooling system and connect the negative battery cable. Step4 Operate the cars engine until it reaches normal operating temperature. Watch over the climate control operation and check for any leaks.
Mar 06, 2009 | 1997 Saturn SL
Bad radio reception
Problem: Radio Reception is bad to non-existant. AM is usually worse than FM.
Reason: Antenna connector has come loose, and needs to be reconnected. This happens when a passenger pushes the carpet toward the firewall and disconnects the plug.
Affected Model Years: 1997, 1998, 1999, 2000, 2001, 2002, 2003
Permanent Fix:
1. First check to make sure the antenna at the back of the radio has not come loose.
2. Remove the plastic cover on the front passenger door threshold held in place by three pressure clips.
3. Peel back the carpet on the front seat passenger floor.
4. Locate the coax antenna cable running along the side.
5. Reconnect the two pieces of antenna that have come loose.
6. Roll the carpet back, and re-install the threshold cover.
Nov 01, 2008 | Kenwood KDC-119 CD Player
Washer stuck on Pause mode
Remove the washer from the electrical supply.
2. Remove the top panel and disconnect the wire plug to the pressure sensor.
3. Reconnect the washer to the electrical supply.
4. Press start and wait 10 seconds (washer will drop out of the continuous loop).
5. Remove the washer from the electrical supply.
6. Reconnect wire plug to pressure sensor and reinstall the top panel.
7. Reconnect the washer to the electrical supply and verify proper functionality.
8. If same symptoms occur, install a new console control.
Dec 30, 2007 | Frigidaire Affinity ATF7000EG
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
