Acer adaptor i need adaptor what is the volt
    New Friend:
  • 12 Answers
230 v, ac
Posted on Apr 24, 2013
I'm traveling to India where electricity is 240. Do I need to buy a power converter for my Asus laptop?
most laptop power supplies support full range power input. meaning it will accept any normal outlet voltages used anywhere. if you look at the power supply of your laptop it should say vin (voltage in) 100v to 240v 50/60 hz, or close to that if it is.
Nov 01, 2016 | ASUS Computers & Internet
I have a model-JJB052000-2509 50/60 H2 Output5V-2000mA and I need power adaptor can you help me?
pls let me know where do u live,,you need 5volt 2 ampere adaptor,,u may use 2-5 ampere also,,volts should be =5 volts,,,u can charge ur note with laptop usb connector also,,,or u can find this adaptor on amazon.com,,,ali express,,,or any other as per ur area
Jan 27, 2015 | Archos 101 Internet Tablet 16GB 10.1"...
How can I fix the network adaptor on acer aspire v3?
Simply go to www.acer.com and download the driver for the OS & model.
May 20, 2014 | Acer America Acer Aspire V3-571-6643 Intel...
What size/type ac adaptor do I need for my Acer Aspire 5100-3357?
Volts: 19 - Watts: 65 - Amps: 3.42
http://www.amazon.com/Acer-Aspire-5100-3357-Adapter-Replacement/dp/B00337X5I6
Oct 26, 2011 | Acer Aspire 5100-3357 Notebook
No power. no lights. I have checked the power cord and its like there is no power
Firstly check that there is power to the Ac adaptor, this can be done by seeing if the green power indicator light is on on the adaptor body.
If not, then you have a defective plug, blown 3 amp fuse or the adaptor is fried (not uncommon)
If you have a multimeter, you can set it to 20 volts DC and with the adaptor pligged into the mains, test the DC JACK end! by putting the red probe to the inner part of the jack and the black to the outer part, if no reading, then assume the adaptor is dead.
Best way to check is by testing with an adaptor (universal charger type) to see if that works.
Assuming the adaptor is putting out power, check the output with a multimeter as above and see if the voltage is at the correct level (think its 19 volts on that model). If it is, then move on to the DC jack connection on the netbook
Watch the power indicator on the adaptor, if it is not steady green (ie flashes on and off), ther power is not making a circuit in the alptop and is being "spat back", this can be anything from a blown circuit board in the power circuit, to something as simple as a motherboard main fuse.
If there is a staedy green light but no power at the netbook and the jack connection at the netbook is firm and not sloppy or loose, then you will need to have the netbook dismantled and the fuse checked ( this will also need to happen if the jack connection is loose.
Sometimes, removing the battery, pressing the power button on (with the adapator unplugged) for 30 seconds and repowering with the ac adaptor can reboot the system, but I'd be inclined to suspect the adaptor first
Apr 22, 2011 | Acer Aspire One PC Notebook
Need driver for Acer ethernet adaptor
try going to the acer support page and looking for the driver download----also, you can try driverguide.com. they are all free downloads and you might find it there
Apr 25, 2010 | Dell Intel Ethernet Adaptor 0000921206...
Acer 9410 will not run off AC adaptor or charge the battery. It will run on a charged batt, any ideas? there is 19 volts coming from the charger. Thanks
Have your Adaptor/Converter checked by a licensed technician. It would be good if it is still under warranty but if not I recommend you bring it for servicing.
Jan 25, 2010 | Acer Aspire 9410 Notebook
I don't have wireless network on acer aspire4715Z
The Aspire 4715 comes with Wireless OPTIONAL. Your system obviously wasn't bought with a pre-installed wirelss card. If you want to go wireless, you will need to buy a wireless card/adaptor seperately.
Nov 29, 2008 | Acer Aspire 4720 Notebook
Acer aspire 3610
Depending on the system and the supplied adaptor type, substituting another can result in damage.
Some adaptors (nearly all 'universal' or adjustable types) are very primative and have little or no regulation meaning that the output set and the output you actually get are highly load dependent and the actual output voltage can be 50% higher than set.
Most laptops use a somewhat better adaptor (more stable output) and have internal final regulation to service the unit's needs and charge the battery pack at the same time.
Using the wrong adaptor can seriously damage the unit's internal regulator and you may have already done that even though the stated voltage is only 3V or some 25% higher.
If the laptop no longer boots, you may have some expensive repairs ahead.
May 13, 2008 | Acer Aspire 3610 Notebook
Portable fm/am/sw radio
yes you did! you overstressed the components of the radio plugging a 6V instead of a 3V adapter!
Nov 01, 2007 | Audio Players & Recorders
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
